It is currently Mon May 19, 2025 6:52 am
 Post subject: CR480 Cylinder
PostPosted: Thu Feb 17, 2011 5:35 pm
Here is the cylinder I would be adapting to the FL350 bottom end, looking at the port layout its probably what they used to make a few of them race engines.
This is Nukems cylinder.
Needs bored its well worn looks like it was run hot for a while lol the wear is shown by running a ridged hone over the cylinder sunnen AN-112 a flex hone wont show you this.
DSC08526.JPG [62.38 KiB]
Downloaded 169 times
DSC08529.JPG [67.14 KiB]
DSC08530.JPG [69.18 KiB]
DSC08531.JPG [97.93 KiB]
DSC08533.JPG [86.38 KiB]
DSC08534.JPG [71.95 KiB]
DSC08535.JPG [75.46 KiB]
 Post subject: Re: CR480 Cylinder
PostPosted: Mon Feb 21, 2011 1:43 pm
Thanks for the cleanup/inspection. Bad news is they don't make a YZ490 piston that big(90mm---.80 over max) so a new sleeve will be required. Crap. Max on a CR480/500 piston is 91.00MM but they use a 20mm wrist pin and the fl350 and YZ490 rods use 18mms.
PostPosted: Mon Feb 21, 2011 7:39 pm
can you find a different rod ?
or over bore a stock rod to fit ?
look at a seadoo pwc 1997 650 the rod is very close with a 20 mm small end piston pin bearing is 20x25x22
SpeedChaser :-)
PostPosted: Wed Feb 23, 2011 10:47 am
Good idea Speed, nice to have options. I had not thought about that...but I am still going to be short for a wide enough piston. There may be a few other big bore piston models(91.50mm???) but then I got to start watching for wrist pin to dome distance(deck height?). The whole thing was an experiment, air cooled jug so would not do well on long runs anyway. I was originally looking at milling down the CR500 jug. I still like the shorter rods rev over the longer rod trq...but that's just me. Again, thanks for the inputs!
Gary
PostPosted: Wed Apr 06, 2011 1:45 pm
SpeedChaser :-)
What catalog are you getting those screen caps from ?
PostPosted: Wed Apr 06, 2011 9:21 pm
SpeedChaser :-)
I will have to look I will post the whole thing if I can find it again
hot rods
http://www.hotrodsproducts.com/ProductSearch.aspx
use the request a catalog button its in pdf
http://www.pro-x.com/eng/default.htm?catalogue.htm~ProxMain
prox
PostPosted: Thu Apr 07, 2011 7:02 am
Strange, the hot rods link doesnt show 350 rods. The only rod rebuild I had done had a hotrod kit in it. hmmmm
PostPosted: Thu Apr 07, 2011 7:34 am
I think the cr250 is close to the same I posted this some ware
speed
PostPosted: Thu Apr 07, 2011 8:23 am
Cool, Thanks, must have missed that somewhere. I have several cranks around here. They are marker either "S10" or "S11". Never noticed that before, wonder what the difference is? Different runs or maybe the CR250 rod?
PostPosted: Thu Apr 07, 2011 8:30 am
found it
http://www.pilotodyssey.com/PO/viewtopic.php?f=1&t=7184&hilit=rod
speed
PostPosted: Thu Apr 07, 2011 9:39 am
Good research speed!, Thanks
Registered users: Baidu [Spider], c5racer, Google [Bot]
