It is currently Tue May 20, 2025 12:17 am
PostPosted: Sun Apr 03, 2011 7:40 pm
Thread can be viewed here on the 3 wheeler board:
http://www.3wheelerworld.com/group.php? ... do=discuss" .".." .".." .".." ."..
Here is some pictures of the build as well!!
http://s733.photobucket.com/albums/ww33 ... %20begind/" .".." .".." .".." ."..
http://s733.photobucket.com/albums/ww33 ... 0pictures/" .".." .".." .".." ."..
http://s733.photobucket.com/albums/ww33 ... se%20woes/" .".." .".." .".." ."..
File comment: Old motor (( Internal Combustion Engine ? )) before removal
2nd tecate pic 4.JPG [147.68 KiB]
Downloaded 87 times
PostPosted: Mon Apr 04, 2011 8:05 pm
Some motor (( Internal Combustion Engine ? )) pictures for you atc fellas!! I got the ride all back together and finally ran it today for some heat cycles. It ran great, everything is tight and running smoothly. Cannot thank SPEEDCHASER and Hoser enough for all the help on this!!!!
File comment: Finished product
PostPosted: Mon Apr 04, 2011 8:31 pm
The radiator hose looks close to the head pipe?
Sending the seat out to that couple on the 3 wheeler board for a upgrade?
PostPosted: Mon Apr 04, 2011 8:34 pm
Just a camera angle Hoser, it is well away from the exhaust. And YES I am waiting on a seat from the company that does the seats at the 3 wheelerforum. Heres the website for them, do a good job!! Thanks again for the all the tech help on this rebuild Hoser!!
http://www.cosmicquads.com/4436.html
PostPosted: Sat Apr 09, 2011 5:30 pm
ok update. I was running the Tecate today heat cycling the motor (( Internal Combustion Engine ? )). I did a check of the fluids and found pepper like flakes in the rad. Drained the oil and it was milky. No good. Checked around the head and found a slight trail of antifreeze going down it, as well as a small amount accumulated on top of a head nut. Head gasket woes it seems to me. I pulled the plug,and it was rich but nothing to indicate burning of anitfreeze at all.In the picture is the nut where I found anti-freeze accumulated on-it is directly in front of the Engine mount.
File comment: Here is the oil drained, this oil has like 5 minutes on it and it was hot when drained. Head gasket?
PostPosted: Sat Apr 16, 2011 6:48 pm
Had some time today so I changed out the water pump impeller shaft on the clutch side. After removal of the side case I could see coolant inside the case from the seal leaking. I cleaned the seal with q-tips to remove the grease I had put on the old impeller shaft and put the new impeller in, the side case cover as well. I also took the head off as it too was leaking, and replaced with e fresh head and new gasket as well. I ran the Tecate for a spell, drained the oil.Still cloudy. Ran it several minutes at an idle, heated it up, then drained it 2 more times, the oil seemed to get better each time, but there is still a little cloudiness,very limited though. Will the clutch plates and internals keep the contaminated oil on them thus making the oil dirty for a spell?
PostPosted: Sat Apr 16, 2011 10:54 pm
atf will mix with coolant and the high detergent in will clean it out to
this is just a thought
I use this when I have water in a hydraulic system and trying to get water out of it
it will remove the milky looking oil
speed
PostPosted: Sun Apr 17, 2011 9:20 am
Thanks Speed. I'll try that today and see what I get! I am hoping I have fixed the leaking.
PostPosted: Sun Apr 17, 2011 2:21 pm
Drained oil and refilled with ATF. Let it run for a spell, took it up and down the road for a couple of hot runs, then drained the ATF. It was cloudy. I'll refill with 10w-40 and try it again.
PostPosted: Sun Apr 17, 2011 2:39 pm
Ok. UPDATED!! After flushing 2 times with trans fluid is it finally coming out clean.Finally! Doing some heat cycles again with it.After heat cycling the fluid was clean and clear.FINALLY!!! I rode the Tecate briefly around, need a seat and to go down to 20 inch tires in the rear instead of the 22's I have on it. Other then that it is a done deal.Thanks for Hoser and SPEEDCHASER for there time and patience with me and my motor (( Internal Combustion Engine ? )) woes. Looking forward to going out with it in the future.
PostPosted: Sun Mar 10, 2013 10:11 am
SOLD WITH OTHER TECATE
