I am going to go ahead and bring this thread back to life the best that i can.
I first ran across this pilot on eBay and decided that i would watch it. Never really had intentions of winning it because i figured the price would climb well beyond my budget since i would also have to pay for shipping clear across the country (Alabama to Washington). As it neared the end it hadn't gotten bid up way out of control so i decided to place my bid, and i won it at my max bid. One more bid and i would have been out. $657. The description didn't know much about it and the only pictures that were there were the 2 attached below. The seller was selling it to help clear out an estate.
File comment: Ebay Photo
After i won the auction and began making arrangements for shipping the seller contacted me saying that the pilot was in much worse shape than he though. These were the pictures i received. he told me that if i did not want it after these pictures that he would understand. It really was not anything i did not expect, it had been sitting out where it was for 10 years or more.
File comment: Extra Photos from seller
After weeks of dicking around with the shipping company, and having it not arrive on the date that was agreed upon it finally arrived. These pictures are of it fresh off of the shipping truck. Still filled with leaves from Alabama!
File comment: Finally Home
It only took me about 10 minutes before i started tearing into it haha! First i had to get the fenders off of it to make it easier to pressure wash. The side panels were a B**** to get off but finally with my impact gun they came off. This is after its first bath in 10+ Years! And i had to add a family photo of the pilot with its older siblings haha
File comment: After its first bath
File comment: After its First Bath
File comment: Family Photo
So the tear down began, and it did not take me long at all to have a stripped pilot. My initial plans were to use the factory Engine, but when it had a twisted crank my plans changed. I began looking for a good organ donor. I ran across a 1998 Skidoo Summit X 670 that had the crank bearing let go and twisted the crank. The only reason that i purchased it was because it was the entire sled cheap enough that i could part it out and have money ahead plus free Rotax 670HO parts.. a win win!
File comment: Organ Donor
Now that i had the
Engine that i was going to use, it was time to start figuring out an Engine mount. I ran into a delema when it came to mounting positions. Do i mount the Engine high and retain the use of the stock slide mikuni carburetors? Several people here recommended that i use SeaDoo downdraft carburetors because they take up much less room and would alow my Engine to sit down lower in the frame - witch i really liked.
File comment: Do i go high?
Much Better Position
File comment: Ahhh much better
File comment: The lower the better!
File comment: Downdraft 38mm Mikunis and Seadoo Intake
meanwhile....... I had been working on sandblasting every part that would fit into my sandblaster, pretty much everything except the frame, seat pan, and skid plate. Here are some of the results of my handywork. I'm hoping to have a pilot that looks new, sort of a sleeper. The untrained eye wouldn't know that it hauled ass! I also replaced all of the bearings and seals in the rear axle carrier and front hubs.
File comment: Gotta Love Fresh parts!
File comment: Fresh Hubs!
Here are a couple of special parts that i acquired. The first is a disk brake kit. Should help stop this beast! the second is my rear DC shock brackets! should help tame the beast's ride!
File comment: Disk Brakes
File comment: DC Brackets
And that is all that i have for now.
Currently i am working on fabricating the Engine mounts, hope to have them at least tack welded together this weekend. I am also trying to save up for the YODA front suspension kit. If i am going to go rear with fox shocks, why not do the front as well! Sorry for the long post, just trying to re-introduce the thread, and get people caught up on the project that hadn't seen the beginning. You cant just jump into the middle of a build!
