It is currently Mon May 19, 2025 3:15 pm
 Post subject: Large Inventory of Parts
PostPosted: Thu Jan 19, 2012 6:27 pm
Hey Fellas,
Tme to clear out some parts...I am continuing to clear out extra spare parts that are not needed, and or I no longer have a use for them in my shop or current projects. Here is a list of parts and prices. If you need something that you do not see on this list feel free to PM me and I will see if I may have it tucked away somewhere. If you see the items on this add then that means that they are still available. I will remove them as soon as the sale is finalized. I will also add other parts as I come accross them. Please do not be a tire kicker and if you do not have anything positive to say then please hold it to yourself out of respect. If you have any questions please feel free to ask or PM and I will do my best to answer them all in a timely manner. Thank you all in advance. All items highlighted in RED have been sold and are no longer available.
1. Stock FL350R Air box top lid and bottom with stock air filter -$100
2. Reed cage with boyseen reeds - $50
3. Uni 2 stage filter that can clamp to a carb - $10
4. FL400R ATVR ported cylinder - Must be resleaved - $50
5. FL400R Front Right (looking at from front) - $100
6. FL400R Left Rear (looking at from rear) - $100
7. 38mm Mikuni nearly complete - $50
8. FL350R K&N new - $25
9. Straight good condition silver Renthal 790 bars which are the CR Mid Bend 7/8 in size with cross bar pad - $25
10. Tires - Complete set of front and rear nearely new - Ridden on for 3HR ITP Sand Star front 22x8x10 and rear 22x11x10, still have dimples - $220
11. Brand new K&N for Fl350R - $25
12. FL350R Rear Works performance shocks AT Steelers, Non Resi- $385
13. Left Stock front upper and lower J Arms - $75
14. Right Stock front upper and lower J Arms - $75
15. Stock front Left brake drums and spindle with new pads -
16. Stock front Right brake drums and spindle with new pads -
17. FL350R EEE Pipe and silencer - $225
18. Stock FL350R pipe - $60
19. Stock FL350R silencer - $40
20. Stock FL350R seat belt - $35
21. Excellent condition FL350R seat $185
22. 2 Excellent condition FL350R axles $200 each
23. Stock pre recall FL350R head - $40
24. Read cage with built inn stuffer, reeds are boyseen - $50
25. Stock FL350R fuel tank that has already been dip cleaned and resealed - $160
26. Stock pair of front FL350 shocks - $50
27. 102 C clutch for FL350, only used on 4 rides - $300
28. Stock 1989 FL400R pipe and silencer $160
29. FL350R top intake air duct - $25
30. Set of rear ITP wheels for FL350/FL400 – Damaged but fixable
31. Used but in good condition OEM FL350 belt - $20
32. Used but in good condition FL350 Carlisle Hypermax belt - $20
33. Fl350 OEM skid plate - $45
34. FL350 ignition box CDI (Capacitor Discharge Ignition) - $115
35. FL350 drive cover - $30
36. Fl350 camber link set $45
37. FL350 mirrors with boots - 4 available - $40 each
38. FL350 air guide scoops left and right - $80
39. 2003 Honda CR250R fuel tank with cap - $20
40. FL350 front arm brackets - $25
41. FL350 used complete OEM front brake lines - $30
42. Mikuni 38MM TMX - $90
43. 102c cam weights New complete set 58gram -$30
44. 102c cam weights New complete set 60gram - $30
45. Comet 102c Purple spring -$20
46. Comet 102c Pink spring - $20
47. Comet 102c Red/Blue spring - $20
48. Partial Heel Clicker Adjustable Clutch Kit for 102C– 1 of the cam arms will have to be replaced - $75
49. FL350R stock cylinder bore excellent condition - $250
50. FL400R Stock Intake duct and tube , 2 available - $35
51. U shapped shoulder harness blue - $30
52. 2004 Chevy Duramax HD stock air intake with filter and ducting - $70
53. FL400R/FL350R stock intake in very good condition. No cracks ready to bolt on and go- $40 shiped
54. Clarion ADZ625 Cassette/tuner/CD player - Came out of my Denali - $120 shiped
55. Mikuni choke kit New condition - $25
56. FL400R OEM seat harness shoulder pad - very nice condition - $55
57. Brand new Safety Racing wrist restraints - $35 Shiped
PostPosted: Thu Jan 19, 2012 11:46 pm
Have pics of the rear ITP wheels? PM me a priced shipped to 12303 NY.
PostPosted: Fri Jan 20, 2012 6:42 am
Which Works rears? Pics? PM sent...
PostPosted: Fri Jan 20, 2012 1:04 pm
I will be happy to get you some pics this evening .
PostPosted: Fri Jan 20, 2012 1:05 pm
PM replied. They are Steelers Non resi, dual rate white and blue springs.
PostPosted: Fri Jan 20, 2012 1:23 pm
Got a good set of pilot side pannels?
PostPosted: Fri Jan 20, 2012 3:05 pm
Sounds good. Feel free to PM me.
PostPosted: Fri Jan 20, 2012 3:20 pm
I don't know about a good set, I think I may I may have a few different plastics but I think they all have a crack in them somwhere. I will check tonight and take a few pic's.
PostPosted: Sat Jan 21, 2012 12:56 am
PM sent
PostPosted: Sat Jan 21, 2012 1:17 am
I don't see side panels, did you have any?
PostPosted: Sat Jan 21, 2012 2:41 am
Do you have some prices on the 400 fenders??? I might be interested...
PostPosted: Sat Jan 21, 2012 2:56 am
I did not see any, but will check the other shop next week when I head to the farm. There could be one hidden amongst other parts/projects. I will be sure to check for you sir.
PostPosted: Sat Jan 21, 2012 2:57 am
Prices are listed in the list above sir. :-)
PostPosted: Sat Jan 21, 2012 7:50 pm
I don't see the prices listed for them either. Also what ATV cylinder is that?
PostPosted: Sun Jan 22, 2012 2:56 am
Item #5 and #6. $100 each sir. What do you mean about which cylinder, I never ran her, it just happened to ce with a huge batch of parts I purchased way back when. I can mic the cylinder again for the measurement and get back to you tomorrow night.
PostPosted: Mon Jan 23, 2012 1:06 pm
A few more pics of items added and item 50, 51 ,52 added to sale. Take a look and see what you need, if not there then hit me up and I will see if O can locate what you are looking for. Thank you
PostPosted: Tue Jan 24, 2012 4:07 pm
Items 53 and 54 added to the sale, as well as pics:-)
PostPosted: Tue Jan 24, 2012 7:13 pm
PM sent.
PostPosted: Wed Jan 25, 2012 2:02 pm
Items 55, and 56 have been added, as well as several pictures of the other items for sale. I ended up having 2 FL400R stock intake tube item (50), and air ducts and 4 FL350R mirrors in storage item (37). I added the quantity of each which reflects in the updated list. Items highlighted in red have been sold and are no longer available. Please feel free to hit me up with any questions and or inquirys on any parts shown here or not on here. You never know I may have what you are searching for. Thank you all
PostPosted: Thu Jan 26, 2012 12:52 pm
Item 57 and its picture has been added to the sale, as well as a picture of the FL350R Power Bros pipe and silencer that is for sale. Please let me know if anyone needs a particular picture of anything that you are intrested in purchasing and I will see what I can do.
Thank you all
PostPosted: Wed Feb 01, 2012 1:24 pm
8. FL350R K&N air filter - New $25
13. Left Stock front upper and lower J Arms - $55
14. Right Stock front upper and lower J Arms - $55
30. Set of rear ITP wheels for FL350/FL400 – Damaged but fixable - $60
50. FL400R Stock Intake duct , 1 available - $20 each
58. stock honds tool box - 1 odyssey , 1 not sure what it came from - $25 each
PostPosted: Sat Feb 04, 2012 2:36 am
Just got the shocks in today! they look great thank you very much for the great sale :)
I FINALLY HAVE A PAIR
PostPosted: Sun Feb 05, 2012 11:57 am
I would like the #57 wrist restraints. Do you have a stock drive pulley puller tool for the FL 400? 805-798-3996
PostPosted: Sun Feb 05, 2012 3:28 pm
#57 are yours sir. I will send payment info. Sadly I do not have any puller tools for sale for the fl400.
PostPosted: Tue Feb 07, 2012 12:30 pm
Shipped item 57 to you yesterday sir. Thank you for your purchase! :-)
