All items highlighted in RED have been sold and are no longer available.
1. Stock FL350R Air box top lid and bottom with stock air filter -$1002. Reed cage with boyseen reeds - $50
3. Uni 2 stage filter that can clamp to a carb - $10
4. FL400R ATVR ported cylinder - Must be resleaved - $505. FL400R Front Right (looking at from front) - $100
6. FL400R Left Rear (looking at from rear) - $100
7. 38mm Mikuni nearly complete - $50
8. FL350R K&N air filter - New $25
9. Straight good condition silver Renthal 790 bars which are the CR Mid Bend 7/8 in size with cross bar pad - $2510. Tires - Complete set of front and rear nearely new - Ridden on for 3HR ITP Sand Star front 22x8x10 and
rear 22x11x10, still have dimples -
11. Brand new K&N for Fl350R - $25
12. FL350R Rear Works performance shocks AT Steelers, Non Resi- $38513. Left Stock front upper and lower J Arms - $55
14. Right Stock front upper and lower J Arms - $55
15. Stock front Left brake drums and spindle with new pads -
16. Stock front Right brake drums and spindle with new pads -
17. FL350R EEE Pipe and silencer - $22518. Stock FL350R pipe - $60
19. Stock FL350R silencer - $40
20. Stock FL350R seat belt - $35
21. Excellent condition FL350R seat $185
22. 2 Excellent condition FL350R axles $200 each23. Stock pre recall FL350R head - $40
24. Read cage with built inn stuffer, reeds are boyseen - $50
25. Stock FL350R fuel tank that has already been dip cleaned and resealed - $160
26. Stock pair of front FL350 shocks - $50
27. 102 C clutch for FL350, only used on 4 rides - $30028. Stock 1989 FL400R pipe and silencer $160
29. FL350R top intake air duct - $25
30. Set of rear ITP wheels for FL350/FL400 – Damaged but fixable - $60
31. Used but in good condition OEM FL350 belt - $2032. Used but in good condition FL350 Carlisle Hypermax belt - $20
33. Fl350 OEM skid plate - $45
34. FL350 ignition box CDI (Capacitor Discharge Ignition) - $11535. FL350 drive cover - $30
36. Fl350 camber link set $45
37. FL350 mirrors with boots - 4 available - $40 each38. FL350 air guide scoops left and right - $80
39. 2003 Honda CR250R fuel tank with cap - $20
40. FL350 front arm brackets - $25
41. FL350 used complete OEM front brake lines - $30
42. Mikuni 38MM TMX - $9043. 102c cam weights New complete set 58gram -$30
44. 102c cam weights New complete set 60gram - $30
45. Comet 102c Purple spring -$2046. Comet 102c Pink spring - $20
47. Comet 102c Red/Blue spring - $20
48. Partial Heel Clicker Adjustable Clutch Kit for 102C– 1 of the cam arms will have to be replaced - $75
49. FL350R stock cylinder bore excellent condition - $25050. FL400R Stock Intake duct , 1 available - $20 each
51. U shapped shoulder harness blue - $3052. 2004 Chevy Duramax HD stock air intake with filter and ducting - $70
53. FL400R/FL350R stock intake in very good condition. No cracks ready to bolt on and go- $40 shiped54. Clarion ADZ625 Cassette/tuner/CD player - Came out of my Denali - $120 shiped
55. Mikuni choke kit New condition - $25
56. FL400R OEM seat harness shoulder pad - very nice condition - $55
57. Brand new Safety Racing wrist restraints - $35 Shiped58. stock honds tool box - 1 odyssey , 1 not sure what it came from - $25 each
