It is currently Sat May 17, 2025 12:32 am
PostPosted: Sun Mar 25, 2012 4:40 pm
I need a counter balance cover gasket for an FL350.
Thanks, Rand
PostPosted: Sun Mar 25, 2012 5:03 pm
Mudbogger maybe?
PostPosted: Sun Mar 25, 2012 6:12 pm
If you cant find one...make one. A sheet of gasket material is cheap....(like you n me) lol I do it regularly. :-)
PostPosted: Sun Mar 25, 2012 7:19 pm
It's strange, because the gasket set I have didn't have this gasket in it! Usually I trace my gaskets from my set and make new ones and save the originals for masters.
I was looking to get one cheap without having to make one. I managed to salvage 95% of the gasket and I will make one if I have to. I am at the point now that I have used up all of my gasket material and I will have to go purchase new sheets. Figured buying one would be cheaper than buying sheets of gasket material.
PostPosted: Mon Mar 26, 2012 9:51 pm
I will look for you sir, get back to you in a couple days---
PostPosted: Tue Mar 27, 2012 12:38 am
Thanks Mud, just let me know!
PostPosted: Tue Mar 27, 2012 7:30 am
Someone should scan the a decent gasket set on a scanner/copier at 1:1 scale. Then the DIY-gasket-makers will never need a gasket kit. ;)
PostPosted: Tue Mar 27, 2012 7:42 am
Good idea but on this gasket in question he can just use the cover itself, you can lay a piece of notebook paper on it and rub with your finger get a exact outline of what you need.
One of them laser gasket cutters would be the bomb buy a huge roll of gasket material and start making gasket sets :-)
PostPosted: Tue Mar 27, 2012 10:46 am
My sister in law has one of those craft cutters. Too bad they won't cut gaskets! Those would make short work of gasket making!
PostPosted: Tue Mar 27, 2012 10:59 am
Material too thick?
What about one of them small CNC wood carving things?
How about converting one of them vinyl graphics machines to cut them they have to be getting cheap by now?
PostPosted: Tue Mar 27, 2012 11:07 am
Don't know. I've never asked how thick of material they will cut. From what I remember, she paid around 150 bucks for it so it would be cost effective.
If they would cut gaskets, one could recover the cost pretty damn fast!
Registered users: Baidu [Spider], Bing [Bot], Google [Bot], Lanix, Q, socalgii
