It is currently Mon May 19, 2025 7:52 am
PostPosted: Wed May 09, 2012 4:32 am
WTB FL250 RED Right Front Fender
Also FL250 aluminum 3 hole front wheel.
Buy or trade for FL250 parts.
PostPosted: Wed May 09, 2012 4:48 am
http://www.ebay.com/itm/NOS-81-84-Honda ... _500wt_964
PostPosted: Thu May 10, 2012 5:06 am
pilotpete1 wrote:
http://www.ebay.com/itm/NOS-81-84-Honda-FL250-Odyssey-Red-Right-Front-Fender-/290700612446?pt=Motorcycles_Parts_Accessories&hash=item43af1b535e&vxp=mtr#ht_500wt_964" ."..
Arm and leg huh? Anybody got a good used one for like $50.
PostPosted: Thu May 10, 2012 6:48 am
Used arm or Used leg? :-)
PostPosted: Fri May 11, 2012 6:54 pm
I have 3/4 of a set of red fenders that I was saving as spares. Not new or anything but fine condition.
What do you have to trade?
PostPosted: Fri May 11, 2012 7:40 pm
Is the right front the 1/4 missing?
I have small junkyard of FL250,ATC110 parts. 72 Rupp 340 sled Engine with coils,carb and funky exhuast that was on a FL250 when I got it. Never ran it but only fire it up with teaspoon of gas in plug holes. I really like this sled Engine for how small it is and how the clutch is centered to the Engine so much. This is the only sled Engine I seen that will fit in the frame rails in the Ody. You could drop this one low in the frame. The exhuast is facing the wrong way in the pics.
I was keeping this for a later project but parts are not as easy to come by. It has a sweet carb as well. I wanted to polish the aluminum fan case on this one. I have the parts to make it run like pull starter and fan belt eletronice and what not. Also the screen that covers the belt and the other pipe. It needs spark plug boots. Again I was keeping this one for I like how small it is and how the clutch sits. It could be 440 for I cannot remember now. 340 or 440 for sure though.
The exhuast set up I thought was funky. But looking at it it is well made. I did not think it would run well for funky expansion chamber. My old man thinks it would work well. He said they did not have expansion chambers in 72. The setup is sweet for and FL250 though. The Engine can sit low and have seat room with this pipe setup. How it will run I have no clue. Last pics shows the fl250 it was in when I got it. The pipes bolt right to the ody Engine basket like the original does. But one on each side. They are OEM to a yamaha. I am thinking Banshee for they are twins.
My research told me this Engine has the chrome piston walls. Have not checked compression but can. I heard it run for about 3 secounds is all as of right now. Not sure of the carb but it's a big one and is clean.
The aluminum case would look sweet polished.
PostPosted: Sat May 12, 2012 4:02 am
Really needing these fenders. If you have the right front anyway. Needing them for the graduation gift fl250 thread in my world section. I need it by the end of the month or asap.
Have other stuff to trade but where to start? My garage walls are stuffed with stuff.
PostPosted: Wed May 23, 2012 9:08 pm
Yes, I have the right front but it has a 1 in long tear/hole right on the top center, so you would need to do some plastic welding/melting.
That Engine looks sweet but it is probably worth quite a lot more than my red fenders and I wouldn't want to ship it.
If you have an FL250 junk yard, hard to believe you have no fenders!
I need Engine rubber mounts that are not perished, one rear reflector that is not cracked, and one rear wheel inside rim (or the whole wheel).
My son and I are rebuilding one now and we first hored a bunch of parts cars from craigslist. Looking like we have enough to build one good machine now.
I will upload a photo of the fender for you if you are still interested in it that it is not mint.
PostPosted: Thu May 24, 2012 2:24 am
I was able to find a set in my pile that was not cracked. I need to clean them up still. Thanks though.
I have the reflector and wheel for sure.
You have a whole set of red fenders? Post pics of what you got.
Registered users: Baidu [Spider], Google [Bot]
