It is currently Mon May 19, 2025 5:10 pm
PostPosted: Wed May 09, 2012 11:30 pm
I probably have about 20 hours on my Odyssey since the last time I changed the oil. When I changed it last, all seemed fine. It was dirty, but no problems.
Today it started making noise so I headed back to the car. I couldn't put it in neutral after I shut it off.
When I cam home I took out the oil drain plug and just a couple ounces drained. I assumed I fried it. I think I can see a hair line crack in the case, but there was no visible sign of oil leaking.
Here is the strange part. I pulled the oil check screw after that and oil drained out of it. I then added more oil with both the drain plug and the check screw and oil only poured out the check screw. Only small drops would come out the drain plug.
Has anyone ever heard of this?
PostPosted: Thu May 10, 2012 12:20 am
Never heard of that one but try taking out the drain plug and stick a screw driver into the hole and see if it is plugged with the debris for when the tranny possibly let go. I grabbing at straws here but you gotta start somewhere!
Sounds like it is at least time to pull out the tranny, split the cases and inspect it!
PostPosted: Thu May 10, 2012 1:47 pm
Are there parts available to rebuild trasmissions for the FL350? I looked on ebay and its $400 - $500 for a used one.
I'm trying to decide between fixing it and parting it out. Lots of little issues lately. Starter quit working and rear suspension part failed on last ride alone.
Thanks in advance.
PostPosted: Thu May 10, 2012 2:20 pm
What parts are broken if any? This tranny is on ebay, may have some parts you need.
http://www.ebay.com/itm/Fl350-honda-ody ... 1c26e5b35b
PostPosted: Fri May 11, 2012 2:34 am
http://www.ebay.com/itm/Fl350-honda-ody ... 1c26e5b35b" ."..
the link dosent work
PostPosted: Fri May 11, 2012 3:12 am
Thanks in advance.
Where do you live? How much is an FL350 parted out worth?
PostPosted: Fri May 11, 2012 11:03 am
They're worth more in pieces than as a whole.
Here's just a general run down of the big parts and their worth:
Non bent frame 500
foot tub no cracks 200
Non torn seat 150
transmission 350 to 500
Engine as a whole 500
axles 150 plus a set
You get the idea.
My daughters boyfriend Ridindirty just managed to pick up a fairly clean ody that was a runner for $1000. We had to bore the cylinder but that's almost a necessity with a used FL350.
Too bad Carson City it too far for you Big Head, I just acquired an Ody that all it needs is universals and one rear shock. I was thinking of getting an Fl250 for my Grandson who just turned 8 but he is a gig 8! LOL
PostPosted: Fri May 11, 2012 11:54 am
I have that trans forsale I also have a few good starters as well if you need. Let me know thanks
PostPosted: Fri May 11, 2012 4:41 pm
Non bent frame 500
Non torn seat 150
You get the idea.
I missed the part for the fl350 project? You got me thinking now.
PostPosted: Fri May 11, 2012 4:53 pm
Meet half way, go riding, do the swap, ride some more???
PostPosted: Fri May 11, 2012 5:04 pm
Still thinking. Have old friends in Sparks/Reno I would not mind seeing. I have all 4 weeks vacation right now as well. It could be done. The wife is going to be the hard part now.
Send me some pics to me.
PostPosted: Fri May 11, 2012 5:33 pm
I will try to get pics this weekend.....PM Sent
PostPosted: Mon May 14, 2012 2:38 am
I'm almost done pulling the transmission now so I should know in about a week when my buddy cracks it open what the inside looks like. I'll make the final decision then. Thanks so much for the input. I appreciate the heads up on guys with parts. I'll definitly let you know what I decide to do once its torn apart. I'm really suprised there are so many people with parts and also that Honda still stocks so many parts. Pretty impressive for something that is 27 years old.
PostPosted: Mon May 14, 2012 2:49 am
I also have a spare transmission!
PostPosted: Fri May 18, 2012 9:23 am
Ever figure out whats up with the oil?
PostPosted: Fri May 18, 2012 10:56 am
I think he is trying to part it out, this add says tranny died and starter failed much like his first posts
http://www.ebay.com/itm/1985-Honda-Odys ... fe&vxp=mtr
PostPosted: Fri May 18, 2012 11:08 am
http://www.ebay.com/itm/1985-Honda-Odys ... fe&vxp=mtr" ."..
Oh ok thanks, good luck with the sale.. Hopefully he will then buy a Pilot :-)
PostPosted: Fri May 18, 2012 6:56 pm
I posted this thinking that if I could sell the Engine, but I doubt I can get $700 for it and that is after $375 to put in a new top end last month.
I'm still looking for parts. My main concern is I can't seem to find an AB gear and the dealer can't order it anymore either.
Does anyone have a tranny they are parting out? I know I need the following parts.
1,# 5$200 1,#17 not available 1, #24? 2,#33? 2,#25
http://www.chucklenuts at aftershot motorspurts.com/Ho ... 20a&page=1
PostPosted: Fri May 18, 2012 7:26 pm
Thought Randy at http://www.pilotodyssey.com/PO/viewtopic.php?f=2&t=16721 had a bunch of AB gears made up?
PostPosted: Thu May 24, 2012 12:04 am
Ouch - I tried the Odyssey salvage site, but it would be a little pricy for everything I needed. I went ahead and sold the Engine on ebay and am parting out the rest. Thank you everyone for your help.
