It is currently Sat May 17, 2025 4:30 pm
Post new topic Reply to topic  [ 30 posts ]  Go to page 1, 2  Next
 Post subject: Parting out FL350
PostPosted: Mon May 14, 2012 12:11 pm
Hi, I have a Fl350 I'm going to part out. I could use the money to finish mine out. If there are any parts you guys need just ask. I wont be selling the Engine, trans, or axles but anything else I have from it will be for sale. Prices will be very good for people off the forum. just let me know what you need asap, the rest will go on eBay this weekend. Thanks
 Post subject: Re: Parting out FL350
PostPosted: Mon May 14, 2012 1:40 pm
if you have a good foot tub TPreed has been wanting one.
PostPosted: Mon May 14, 2012 1:43 pm
Thanks, it has some cracks but I'll send him over a picture when I get it off and let him decide if it'll work for him. Thanks
PostPosted: Mon May 14, 2012 3:43 pm
YES I NEED ONE. Cracks are OK i can zip them up with fishing line! Mine has a hole the size of a bowling ball!.. do you also have the steering sides and front covers? there will probably be some other stuff Ill def need as a redo this front end.. maybe ill swing out your way and we can have an oddy garage sale?!!! :)
PostPosted: Tue May 15, 2012 1:43 am
Do you have an aftermarket pipe for the Ody your parting out.
PostPosted: Tue May 15, 2012 2:58 pm
Tpreed- pm sent
Randman- I do not have an aftermarket exhaust. I have a full stock exhaust.
PostPosted: Tue May 15, 2012 11:32 pm
Got any tie rods in good condition?
PostPosted: Wed May 16, 2012 12:41 am
Hey what about the master cylinder..
Odysseyfreek
PostPosted: Wed May 16, 2012 7:38 am
It does have tie rods. They are an aftermarket set. $40 plus actual shipping.
PostPosted: Wed May 16, 2012 7:45 am
Odysseyfreek
I've got one. Might need rebuilt. Tpreed gets first shot at it but if he doesn't need it $50+ shipping.
PostPosted: Wed May 16, 2012 11:11 am
Are they the type where you have to drill the knuckle and flag to a larger size?
PostPosted: Wed May 16, 2012 11:19 am
I'm not sure. I'll check later and let you know.
PostPosted: Thu May 31, 2012 1:21 pm
Sorry it took so long. I do believe the tie rod end bolt is a larger diameter. I'm not sure on the flag but I'm selling them with the flag that they are bolted to. I've got some pics I'll email you and Ridin dirty. Thanks
PostPosted: Thu May 31, 2012 1:39 pm
I'm not sure if you are keeping it or not, but I nmeed the rubber intake boot that goes from the head to the carb, and the rubber boot that goes from the carb to the airbox. And the hose that goes from the lower airbox to the upper, and possibly the lid to the lower airbox. I also need an ebrake cable and shift lever
I need the guards for the drive belt and gas tank, along with the upper gas tank mount. Just the upper part that bolts onto the lower with the rubber isolator.
I also need a good stock gas cap with ignition key and ignition switch.
PostPosted: Thu May 31, 2012 3:18 pm
Wow I struck out on this one. I don't have any of those parts left. Sorry
PostPosted: Fri Jun 01, 2012 2:04 am
Pm sent....
PostPosted: Fri Jun 01, 2012 1:22 pm
Do you have a gas tank available? Stock or aftermarket?
PostPosted: Fri Jun 01, 2012 2:05 pm
Save your old tank I want to wash and flush it out until you cant smell gas any more then purge it with nitrogen as I cut a big ass hole in the side to see whats wrong if its repairable will tig weld it back together save for a spare, biggest thing is to CSI the tank once we see what happen maybe we can fix it externally in the future?
PostPosted: Fri Jun 01, 2012 2:13 pm
This buggy didn't come with the original tank. Don't have an aftermarket either. Sorry Nelly. You up for a cliffs trip soon?
PostPosted: Fri Jun 01, 2012 2:39 pm
If I cant come up with another tank soon and for the right price, I am just going to modify my current tank. I'll add my own fitting to draw fuel from near the bottom and bypass the stock reserve/main/off valve. Assuming this is my issue. I will be trying my Dads remote tank this weekend to see if in fact my tank is the issue.
Ok, no problem. Yeah, I'd be down for a Cliffs trip. Just gotta get the Ody to stay running first.
PostPosted: Fri Jun 01, 2012 2:52 pm
How are you planning to modify?
PostPosted: Fri Jun 01, 2012 3:01 pm
I was going to pull the tank and have a threaded insert welded to the tank near the bottom. Then I could screw in a fitting that I can attach my fuel line to. Then I would just be drawing from near the bottom of the tank much like the stock reserve line does.
PostPosted: Mon Jun 11, 2012 10:23 am
Hey Fatcat, do you have the plastic steering wheel cover available?
PostPosted: Mon Jun 11, 2012 10:52 am
I believe I do. I'll have to check the condition when I get home. I'll let you know ASAP.
PostPosted: Mon Jun 11, 2012 11:17 am
Awesome, thanks!
