It is currently Wed May 21, 2025 11:23 am
 Post subject: fl350 carb?
PostPosted: Sun Jun 17, 2012 12:05 am
im needing to get a carb for my odyssey im putting together
i got the stock carb
the fl350 is air cooled
has an dg chamber pipe with a turbin core 2
stock air box i'm going to moddify it
stock reeds
im wanting to get a pwk
im thinking abought a 38 or a 39
what do u think i should get ?
and a base line for jetting?
 Post subject: Re: fl350 carb?
PostPosted: Sun Jun 17, 2012 12:16 am
does any one think one of these would work ?
http://www.ebay.com/itm/Yamaha-Yz250-Ke ... 804wt_1133" .".." ."..
theres one for sale in my town for $60
im just thinking abought picking it up any ways to re sell
or
http://www.ebay.com/itm/SHIFTER-KART-CA ... 500wt_1133
PostPosted: Sun Jun 17, 2012 12:19 pm
Ask to see pics of the slide on any carb before you buy.
60 bux is cheap for that carb like you said you could always resell, also ask for the stock float bowl in case their is a clearance issue with that over sized bowl on your Odyssey.
PWK is the way to go IMO then the stock cable choke just screws right into the PWK.
350 guys can advise on baseline jetting.
PostPosted: Sun Jun 17, 2012 6:12 pm
Well I'm sol
I just found out my intake boot is ripped and didn't notice it till now
Would this one work
http://www.ebay.com/itm/M-FL350-Honda-F ... bb&vxp=mtr
Cuz you can change out the rubber mount
The olny reason I think it will
Cuz I got that 05 Yz 250 carb
And it's bigger any ways On the mount
PostPosted: Sun Jun 17, 2012 6:28 pm
That part would work but its WAY over priced it also needs reed petals they start at about 35 bux a set, then where do you get reeds, figure in shipping for the two items your at 200 bux and you have no idea what condition the rubber part is in.....
What about one of these it would put your carb center of the intake would that matter?
http://www.pilotodyssey.com/BTmanifold.htm
Looks like you can still buy one for Price: $50.44 http://www.powersportsplus.com/parts/detail/honda/HP-16221-430-000.html
PostPosted: Sun Jun 17, 2012 11:45 pm
i need a intake that has a 45mm intake boot mount to fit the carb i got
i was thinking abought making a plate to mount a 45mm rubber pingal mount to
and use a stock cage
PostPosted: Tue Jun 19, 2012 11:12 am
is there a way to fix the older intake manafold?
like vulcinaze it?
BS
PostPosted: Tue Jun 19, 2012 11:54 am
like vulcinaze it?
BS
Not that I know of you would need a rubber expert and it probably would still be a gamble, you you willing to bet a burnt piston on a manifold?
PostPosted: Tue Jun 19, 2012 12:11 pm
like vulcinaze it?
BS
hoser I thought you were working on an experiment with softening the rubber?
PostPosted: Tue Jun 19, 2012 1:50 pm
redskinman wrote:
like vulcinaze it?
BS
Yes I am.
PostPosted: Sun Jul 08, 2012 2:33 am
like vulcinaze it?
BS
not really wanting too
im thinking abought putting the cbr 600 Engine in the other frame
just so i can save my $$$ and make my current one baller
