It is currently Sat May 17, 2025 12:19 pm
PostPosted: Fri Jul 13, 2012 1:53 pm
Ive got 2 complete engines worth of parts and some other odds and ends. I have yet to post pictures because its a PITA to post that many pics. ill list what i have, and if there is interest i will post pictures.
1. Comet 94c clutch low hours - sold on evilbay
2. FL350 stock carb, very clean
3. FL350 bottom end, i beleive recent rebuild, bearings tight comes with flywheel/stator starter gear, ballancer and all related parts.
4. Top end. current on 81mm bore. needs bored to 81.50. I have a piston kit and Honda needle bearing ready to be put in. just need the cylinder bored.
5. Top end 2. wiseco piston measures just under 80mm. top of it too hammered to read the stamping. cylinder needs bored.
6. FL350 cases good shape not broken. No bearings has ballancer and ballancer cover
7. pullstart, i have 2. one could use a new string. both work great
8.Starters, i have 2. one is a good working stock, and the last is a broken stock. the comm is too worn to accept a set of brushes. good for parts for the gears and whatnot.
9. FL350 crankshaft. In good shape, i think it is usable. was in a running machine. Lost top end and tore it apart because there was a little endplay in the crank. bearings were shot.
10. heads, i have 2. one has only a couple nics in it from poofkabooms and the other has been pelted. still in nice shape. very usable. these are the curved fin heads
11. Stator - works great was in a running machine
12. reed cage - has boyesen reeds. in good shape
13. electronics. sandblasted mount. CDI (Capacitor Discharge Ignition),coil and regulator in great shape
14. msc Engine gears. flywheel starter gear, balancer gears ect.
15. NOS FL350 rings 13011-VM0-305
if interested let me know. Not sure exactly what to ask for everything but sorta have an idea what it is worth.
PostPosted: Mon Jul 16, 2012 3:09 pm
How much for the 94c clutch? Shipped to 23111
PostPosted: Mon Jul 16, 2012 4:30 pm
asking 150 shipped. new i paid 250
PostPosted: Tue Jul 17, 2012 12:33 am
Thanks for the response. I asked for a price as mine was not working, but now it is.
PostPosted: Fri Jul 20, 2012 2:58 am
Bump, added number 15, a set of rings. need all this stuff gone... just bought a truck. goes to evilbay after this weekend
PostPosted: Sun Jul 22, 2012 2:06 am
How much for a topend?
PostPosted: Sun Jul 22, 2012 2:16 am
I would like 250 for this one. remember comes with brand new piston kit and wrist pin bearing.
I would like 150 for this one, comes with bad piston
PostPosted: Wed Aug 01, 2012 2:38 am
Bump
PostPosted: Tue Aug 14, 2012 5:12 pm
bump :shock:
Id take $750 for everything if you wanted to buy it all.
