It is currently Sat May 17, 2025 7:43 am
PostPosted: Tue Aug 28, 2012 3:17 pm
Drak::
2001 DRAKART Formula Cross, 585 Bombardier, 2-Stroke, 110 hp, has heavy duty rear axles too....Damn fast !!!!!
Located in Redondo Beach, Calif, near LAX.
DRAKART was Purchased for my wife who was paralyzed in an UN-related accident,
We equipped it with HAND-controls from a Honda Odyssey . See Photos.
We bought this DRAKART in 2007,
It is very fast, in good condition, brand new carbs, only used 10x since 2007.
The DRAKART does not fit our family needs any more.
We have two small kids and we are looking for a 4-stroke - 4-SEATER for the family....
We are willing to consider TRADE for a 4-SEAT UTV - Side by Side - RZR type.
Or you can make an offer on the DRAKART.
Was Purchased in 2007 for $ 13,000.00 so I wont budge much on the $10K
contact Tim 310 408-9600
Also see on EBAY http://cgi.ebay.com/ebaymotors/ws/eBayI ... 0971815675" .".." .".." .".." .".." .".." .".." .".." .".." ."..
PostPosted: Fri Sep 14, 2012 3:11 pm
Ten Grand!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! Wow :shock:
PostPosted: Fri Sep 14, 2012 4:14 pm
Looks like a nice machine.Just an FYI, those controls look like a Pilot wheel instead of an Odyssey since the master cylinders are on the wheel, and the warning lights. Good luck with the sale.
PostPosted: Sat Sep 15, 2012 11:46 pm
will you trade for a pilot with a new motor (( Internal Combustion Engine ? )) and a trophy kart
PostPosted: Sun Sep 16, 2012 1:50 am
Why is this thread in the tech section and not in the forsale area???
PostPosted: Sun Sep 16, 2012 11:22 am
Any I never even noticed lol I just use the "View new posts" link and never read what section its in, only takes seconds to move so I moved it to FOR SALE :-)
PostPosted: Mon Sep 17, 2012 11:44 pm
the more i look at this car the more i want it!!
PostPosted: Sat Sep 22, 2012 7:50 pm
Ten GRAND !!!!!!!!!!!!!!!!!!!!!!!!!!! :shock:
PostPosted: Sun Sep 23, 2012 12:52 am
I found another one with the same Engine,bead lock's and nerf bars for 8k Im going to buy it. I have a pilot for sale. Fox shocks all the way around LT in the front and a brand new hoser Engine. Lets start at 6k and go from there.
PostPosted: Thu Sep 27, 2012 8:08 pm
Does anyone know how much of a project it would be to upgrade the steering to close ratio since you have to cross your arms to turn with the Pilot steering wheel?
PostPosted: Thu Sep 27, 2012 10:42 pm
I installed a Howe 2:1 steering quickener on my 02 Drak,it brought the lock-lock positons exactly like the Pilot's.
It's just a matter of fab'n up some holding brackets and being accurate in where you cut the steering column.
I installed mine as low as poss-near the R&P steering box,just incase I needed to add or change anything later on up the steering shaft/column.
Luckily I did that because I did'nt factor in the extra turning effort required as a consequence of the SQ 1:2 ratio.
I then had to add in an electric power steering kit from Unisteer,I think I picked the Yamaha Rhino one,as it came with good brackets to work/mod from and uni-joints hardware.
I also had to increase my stator output(custom 400W from RM Stator) and battery size to FEED the EPS power demands! :shock:
So you see the domino effects?
Bottom line,"Is it worth it all?".........................................".Hell Yeah!,it's fo the sake of betterr/responsive racing is'nt it?" Image
PostPosted: Tue Feb 04, 2014 3:05 am
I bought this today and now sits in my garage, he did not get half of this asking price! Broken wheel bearing found rite off the bat. Major changes coming this summer
PostPosted: Tue Feb 04, 2014 3:11 am
I will let you know, that is 1 of the first things on the list
PostPosted: Tue Feb 04, 2014 12:02 pm
Halo has already done this. Installed a pilot wheel, power steering, and a 2:1 quickner. With the quickner, you HAVE to add power steering, it makes the steering way too stiff. And you HAVE to use a 2:1 quickner. Halo initially used a 1.5:1 ratio quickner and it did not provide enough throw.
PostPosted: Tue Feb 04, 2014 2:17 pm
Or be a man and drive it without power steering :-)
PostPosted: Tue Feb 04, 2014 2:25 pm
5-1 wow
PostPosted: Tue Feb 04, 2014 3:16 pm
Wat about us old farts who have bad shoulders?
PostPosted: Tue Feb 04, 2014 6:16 pm
electric power steering and 2-1 steering quickner will find its way onto this car forsure.
PostPosted: Tue Feb 04, 2014 9:17 pm
If you ditch the stock axles let me know Dave !
PostPosted: Tue Feb 04, 2014 11:58 pm
I will be doing a full suspension update durring the summer Brit, when I do I will let you know. My plan is to leave it alone till the summer break and tear into it
PostPosted: Thu Feb 06, 2014 4:10 pm
I just noticed in the pictures that the righr rear axle assybley is missing!, found things on this car that sre wrong, still not bad at 4400 but I wish I would have noticed these things
PostPosted: Thu Feb 06, 2014 4:52 pm
haha no shit I see that now you pointed it out, I never even bothered to look that close just assumed it came with both axles, hope nothing else is missing.
PostPosted: Tue Jun 03, 2014 1:23 am
Hi Dave-co, Did you source an axle for this machine, or was that picture taken with the axle out for repair and has since been replaced?
It wouldn't be driveable with an axle missing, the rear wheel would just be flopping all over the place and the car would just go round in circles everytime you hit the throttle, well it would pull pretty violently to the right.
If you found an axle where did you get one, Brittabrat is in dire need of axles for her machine.
Cheers
Dave
PostPosted: Tue Jun 03, 2014 1:00 pm
it came with the axle, I didnt notice untill I got it home that it was missing in the picture but that side wheel bearing was bad when I got it home
Registered users: Becerra, Bing [Bot], Google [Bot]
