It is currently Mon May 19, 2025 1:38 pm
 Post subject: Fl350 intake boot
PostPosted: Mon Oct 15, 2012 3:47 pm
I have a repair question...
I was doing some repairs to my Engine on Sunday and found some cracking on my intake...
I have a spare and its been changed already!
Can a intake boot on a fl350 be fixed? I have a few small cracks in the top of my intake to the carb near the aluminum. They don't go all the way through yet but they may someday! Can I fix this before it breaks all the way though or no? If so what can be used?
Thanks...Randy
 Post subject: Re: Fl350 intake boot
PostPosted: Mon Oct 15, 2012 3:51 pm
viewtopic.php?f=1&t=10354&hilit=rubber
Hoser - how did it turn out?
PostPosted: Mon Oct 15, 2012 4:10 pm
Messer-thanks for the link, are you going to be joining us at the badlands this weekend?
I'm gonna wait for hoser to chime in to see if he has results from his testing...
PostPosted: Fri Nov 30, 2012 2:08 am
There's another intake boot from an atc or cr 250 that will work but it goes strait insed of going to one side
PostPosted: Fri Nov 30, 2012 1:51 pm
as far as repairing a crack, there really isnt a way to fix it. what hoser's link is for making a stiffened up manifold soft again. DO NOT attempt to coat in silicone, it will fail and suck dirt/air
PostPosted: Fri Nov 30, 2012 2:41 pm
They turned hard again in a month
PostPosted: Fri Nov 30, 2012 4:05 pm
Yeah I saw that, but Randy is trying to repair a cracked boot, not soften his up.
PostPosted: Fri Nov 30, 2012 4:11 pm
I did catch mine before it cracked all the way through. Can It be repaired w silicone or anything else or is garbage?
PostPosted: Fri Nov 30, 2012 4:16 pm
Thanks...Randy
Not worth fixing imo
Not worth risking burning up an Engine for
PostPosted: Fri Nov 30, 2012 4:49 pm
Toss it. Or, if you are good with aluminum, maybe fab up an intake using your old one, remove the rubber completely, weld on a plate and an inlet and use a piece of silicone hose to clamp the carb on.
PostPosted: Fri Nov 30, 2012 4:54 pm
Anyone have a kid in High school taking metal shop?
Have someone sand cast one!
PostPosted: Fri Nov 30, 2012 5:00 pm
ok, has anyone bought a new boot from "Joe" in ny for $129?? are they any good? IF its worth it ill buy one instead of buying 3 used ones and they all fall apart... Randy
http://www.ebay.com/itm/HONDA-FL350-ODY ... da&vxp=mtr
PostPosted: Fri Nov 30, 2012 5:12 pm
Don't know if anyone needs this info but the sand they used in our high school was red in color and was called petrobond. You added some water and your ready for sand casting. I think it came in 50lb bags. Don't remember the price.
PostPosted: Fri Nov 30, 2012 5:30 pm
http://www.ebay.com/itm/HONDA-FL350-ODY ... da&vxp=mtr" ."..
I purchased two of these to use on Ody's I rebuilt for Duneit. They are well made but the rubber boot area is made from urethane and it thinner than the factory boot.
So far so good, Dave hasn't had any issues with them yet.
