It is currently Mon May 19, 2025 2:21 am
Post new topic Reply to topic  [ 51 posts ]  Go to page Previous  1, 2, 3  Next
 Post subject: Re: wanted Drakart frame
PostPosted: Mon May 27, 2013 12:27 am
B S wrote:
halorising wrote:
Hope your better soon how is the pain, any surgery required?
pain when i move id say 8 out of 10
Ill know tomorrow if i need surgery. The Dr. at the hospital thinks i will, he said to many breaks.They can see three and looks like more but the swelling is blocking it
what happened ?
had a mri next dr. apt tue
PostPosted: Mon May 27, 2013 12:32 am
what happened ?
I ment what happend to you that you need an MRI ?
PostPosted: Mon May 27, 2013 2:38 am
He hit a pole at 40 mph last weekend in his drakart during our race and the frame tacoed in on his legs and broke his knee in 3 places and messed up his ligaments.
PostPosted: Mon May 27, 2013 11:46 pm
shit
any photos ?
hope your mri goes well halo
PostPosted: Tue May 28, 2013 12:21 am
Car.
PostPosted: Tue May 28, 2013 12:34 am
shoubadaba wrote:
Car.
damm hit right in the center?
also whos the bald guy?
PostPosted: Tue May 28, 2013 1:09 am
Nope he hit with the left front suspension. that's halo in the pic. First time he has seen the car since he got out of the hospitol.
PostPosted: Tue May 28, 2013 1:12 am
More
PostPosted: Tue May 28, 2013 1:20 am
damm im surprised he diddnt get hurt worse than his knee
that looks knarley
no fixing that
get better halo
PostPosted: Tue May 28, 2013 2:25 am
The car is getting cut at the b-pillar (bar right behind the seat) and a whole new car will be built from the b-pillar forward. New cage and all.
PostPosted: Tue May 28, 2013 8:29 am
Looks like the FG side panel proved itself?
Speedy recovery Halo!
PostPosted: Tue May 28, 2013 9:22 am
Dayuum!
no diagonals in the front?
PostPosted: Tue May 28, 2013 10:20 am
bullnerd wrote:
Dayuum!
Looks like it has as much or more bracing as a Pilot or Odyssey does.
PostPosted: Tue May 28, 2013 10:53 am
bullnerd wrote:
Dayuum!
Yup, probably not much would have helped with a big hit like that.
PostPosted: Tue May 28, 2013 12:11 pm
It has bracing but no enough. The upper section had no cross bracing and the frame is just mild steel yet the arms are chromoly. The arms proved themselfs to be strong and none of them bent or broke. The chassis will be x braced under the leg area and the top tied in as well so this doesnt happen again.
PostPosted: Tue May 28, 2013 12:38 pm
So why don't you use chromoly for the new section of the frame ?
PostPosted: Tue May 28, 2013 1:51 pm
It will be used in areas for more strength.
PostPosted: Tue May 28, 2013 3:43 pm
Really the only good thing about a wreck are the lessons learned & analysis (and the video footage when available).
Seeing how that a-arm set pivoted and pushed-in the cage into the cockpit is scary. With some type of a cross-brace across the "hood" and some triangulation tying in that upper loop with the center loop, you may have either just sheared the spindle off. Or...maybe even ended up with more blunt force to yourself and the "next weakest point" on the chassis.
Always need to have an anticipated weak spot. But there's no effing way in hell anyone can ever predict and prevent every single type, angle, speed, etc of crash. Unless you have FEA software, perfect materials, perfect welds, and a lot of time. Otherwise, just got to over-build it a tad.
Its got me thinking more about my FL350's a-arm conversion plans...
PostPosted: Tue May 28, 2013 3:45 pm
With a straight-edge from the a-pillar to the front bumper intersection, how far is that sucker pushed in??
PostPosted: Wed May 29, 2013 12:04 am
About 10"
PostPosted: Wed May 29, 2013 12:09 am
The Dr. said the MRI shows a broken knee and a miniscus tear or break. After four weeks ill get more Xrays then surgery. eather way its 12 weeks no racy for me.
PostPosted: Thu May 30, 2013 8:57 pm
How do you plan on grafting in a front frame section? Most sanctioning bodies don't allow any type of butt weld on a frame/cage to join two halves together. May be worth looking into before the time and money is spent to fix this one.
PostPosted: Thu May 30, 2013 9:17 pm
The series we race wont look for that and as long as you double Tube it at the seem ( sleeve ) It should be fine. I had to do that for Stock car front clips before.
PostPosted: Thu May 30, 2013 10:07 pm
The way the drak is built is with joint under the b-pillar so that's where it will be cut and sleaved and welded back together just like original.
PostPosted: Fri May 31, 2013 3:58 am
shoubadaba wrote:
<snip>
I don't know about this ?
I endowed my 2003 Drakart Extreme last month 3 times in soft sand and my front left Arm broke clean in half.
I also managed to almost pull the forward mount of the trailing arm off the frame outside the weld.
This was a slower speed tumble down a dune @ LS - I still don't see how your left Arm survived a direct hit ?
I really wonder about its true integrity ?
DR
