It is currently Sat May 17, 2025 2:20 pm
PostPosted: Thu Feb 27, 2014 6:14 pm
PostPosted: Thu Feb 27, 2014 6:21 pm
Do you have a groove worn on your drive clutch faces?
As you know he drive is apart when no spinning. and it looks like the belt is getting worn at the outer edge - so that leads ne to believe the drive clutch faces have a groove worn in them grabbing the outer edge as the clutch spins together and then runs through the groove.
Didn't you have a chirping issue with you clutches?
put a ruler on edge against the drive face and see if you have a worn groove.
PostPosted: Thu Feb 27, 2014 6:33 pm
YESS!!! When ever I gun it it makes a weird noise or chirp
PostPosted: Thu Feb 27, 2014 7:06 pm
Here might be the problem
PostPosted: Thu Feb 27, 2014 7:25 pm
Hmmm...I've noticed that mine makes a weird squeal or maybe it could be called a "chirp" not when you gun it, but when it is returning to idle speed.
This is my first Pilot and the first vehicle I've ever owned with a CVT, so I have no idea what to look for when I hear something I think sounds weird. It's a whole new monster to me.
PostPosted: Fri Feb 28, 2014 1:09 am
YUP you need a new clutch, Is that a powerblock?
PostPosted: Fri Feb 28, 2014 7:32 am
No stock
PostPosted: Fri Feb 28, 2014 2:51 pm
When stock parts wear out...time for an UPGRADE! :-) :-)
PostPosted: Fri Feb 28, 2014 4:28 pm
What do you suggest for a driven clutch upgrade ? Best bang for my buck. I'm not all into tuning clutches
PostPosted: Sat Mar 01, 2014 6:09 pm
get a powerblock
PostPosted: Sat Mar 01, 2014 8:06 pm
where do you get pwoerblocks?
PostPosted: Sat Mar 01, 2014 9:53 pm
I bought my Power Block from ATV racing a couple of years ago, it was about 375 if I remember right...
