A little alignment is needed here too the pipe inside is offset and as you can see in the next
picture with the exhaust manifold installed that the flow of exhaust gases will hit the end of the
pipe and not only restrict flow but will create a hot spot that could ignite the fresh air/fuel
charge coming into the Engine.
With the exhaust manifold installed into the pipe I discovered more flow problems, It is hard to
see in this picture but where it is dark from 2 o'clock to about 7 o'clock the fit is perfect, from 7
o'clock to 2 o'clock where you see the shine metal is where the pipe would stick into the flame
and create a flow restriction. If you think this looks bad you should see the mismatch and
casting flaws in a stock Honda Pilot cylinder
Update: I made the flow corrections (3-11-01)
I used a die grinder with a rosebud tip to hog out the bad spots then feathered it in with a
sanding drum on the Dremel tool and finished up with 220 grit sand paper.
Bad picture I know but after taking 10 pictures I gave up, it is hard to see but starting at 1 o'clock
to 4 o'clock you can still see some of the pipe, the edge has been rolled and moved over to provide
a smooth surface for the exhaust gases to flow over and there is a actually a curve it will flow (no
reduction in pipe size) over, this is much better than it was out of the box, had it not been adjusted
the raw end of the pipe would have been sticking into the exhaust gas flow and create a hot spot
as well as provided a place for carbon to build up.
The whole idea here was to make flow corrections not enlarge anything, the total time to make these
corrections was about 30 minutes, will I see a large increase in power by doing this? Don't know
don't really care what I do know is my exhaust will flow much better for the next several hundred
hours of run time than it did 30 minutes ago
More to come after I get the pipe and silencer installed.
