It is currently Sat May 17, 2025 9:15 am
PostPosted: Wed May 28, 2014 6:52 pm
Here's the Oddy lever...
The geometry of the funky part is a 12pt x 12mm, and the little cam piece simply has a 12mm hex bolt head. Threads of the bolt are M8.
PostPosted: Wed May 28, 2014 7:14 pm
My sketch was posted here:
viewtopic.php?f=5&t=11518&start=25
About 2/3rds the way down the page.
D$, you consider having them lazer blanked?
Simple press brake operation to bend the small tab and weld in the barn.
PostPosted: Wed May 28, 2014 7:41 pm
Thank you Gentlemen, I am going to try the TRX400EX - TRX540R brake lever.
PostPosted: Wed May 28, 2014 7:43 pm
I'm working on making some threw a guy I work with
PostPosted: Wed May 28, 2014 8:51 pm
Good - keep us posted, BS.
I don't know a laser guy, but that 12-pt pattern is really just 3 small squares rotated 120-deg. A plasma may be able to cut it, but laser would be better.
You could always hack up a 12-pt socket and use it if you were desperate.
PostPosted: Wed May 28, 2014 9:37 pm
Not a great picture, but Im sure this is from a 350. The bolt is a little bent, but the bracket looks to be good.
Is it worth about the same as Pilot side panels????
PostPosted: Thu May 29, 2014 2:15 am
BS.....What kind of time frame are we talking here?
PostPosted: Thu May 29, 2014 3:07 am
We are getting stuff cut for work .it should go on the next cut order for our hopper .
I'll keep you informed
PostPosted: Thu May 29, 2014 7:14 am
I worked on this a long time ago still have prints
maybe time to make some
speed
PostPosted: Thu May 29, 2014 7:41 am
Hi Speed
Just a thought
If your looking at doing a run of these have a look at the pilot ones as they have a extended arm to fit a extra
return spring.
The pilot arm does have a larger hole for the end of the parkbrake cable
I have one on my 350
I helps if the cable it not the best
PostPosted: Thu May 29, 2014 10:59 am
I like the idea of the Pilot design for the FL350. I have had a couple of brake cables that like to get crap in them and not return very well. This would help if the FL350 lever you guys make has the additional length so a return spring can be added.
Registered users: Bing [Bot], eseymour72, Google [Bot], redskinman
