It is currently Thu May 15, 2025 3:35 am
PostPosted: Mon Aug 11, 2014 9:42 pm
I am trying to rebuild this FL400 motor (( Internal Combustion Engine ? )) but I cannot find any info on the clutch. I need to find a puller. I might have to make one myself. Any info would greatly be appreciated. Thanks
quick shift clutch .
Quick shift clutch
PostPosted: Mon Aug 11, 2014 9:45 pm
Here is another pic
 Post subject: Quick shift clutch
PostPosted: Mon Aug 11, 2014 10:06 pm
Looks like a quick shift clutch viewtopic.php?t=13788
PostPosted: Tue Aug 12, 2014 5:46 pm
I have one of those ,its called a quick shift clutch
ucp.php?i=pm&mode=compose&action=reply&p=60213
If you look at mine there is a big nut that has a thread on the inside which is used for the puller bolt
PostPosted: Tue Aug 12, 2014 5:59 pm
In lieu of a puller, can the water method by used if you can get the Pilot on it's side or at least 45-50 degrees?
PostPosted: Tue Aug 12, 2014 10:02 pm
It looks like mine is missing that center nut. What does the center nut i. The pic do? Is that just the puller or is that supposed to be attached to the clutch all the time?
PostPosted: Tue Aug 12, 2014 10:09 pm
I have a bolt that threads into the center of my clutch. I just need to make a push rod long enough to puch against the crank. Theoretically that should work to pull the clutch off correct? Then What do I use to mount the clutch Back on?
Also the flywheel puller for the FL400 pilot the same as any other flywheel puller for any other model?
PostPosted: Tue Aug 12, 2014 10:48 pm
The centre nut actually holds the clutch together without it the clutch would not work or worse if you tried it like that it would fly apart when you started the Engine
Did you buy the Engine or buggy with that clutch on it
Was the buggy running when you bought it or was it just a roller
Or maybey the boLt had worked it self loose and fallen out on the trail
Either way im pretty sure you would need that bolt in the clutch so you can screw the clutch puller bolt into
If you like i can pull mine out so you can see what it looks like
Let me know if you need any other information
Good luck ,hope this helps
PostPosted: Tue Aug 12, 2014 11:10 pm
As Danno said, just find a bolt that will thread into the black bolt in these & Danno's pics, (same clutch :-) ) and then just use a cut down punch as a spacer to remove it, or at least that's what I did when that Quick Shift was on my daughters Ody.
I hope this helps
PostPosted: Wed Aug 13, 2014 6:26 am
Thanks for all the info guys!
The pilot has ran this way with no nut on the end of the clutch for years now. We have had this thing for at least 4 years.
Any idea where I can get the nut and puller for this? Or should I just get a comet clutch or something? I am on a tight budget on this rebuild.
PostPosted: Tue Dec 09, 2014 11:05 am
So what did you do about this clutch? Did you find a nut and a puller?
