It is currently Fri May 16, 2025 5:57 pm
PostPosted: Thu Dec 18, 2014 8:38 pm
1990 Rotax Honda Pilot 583cc FL400 MUST SELL fl400R fl583 LONG TRAVEL - $6000 http://ventura.craigslist.org/for/4811367055.html
PostPosted: Thu Dec 18, 2014 8:55 pm
that the one that was for sale in nor cal for $2200
looks like its excaually the same but has some POS foam covering the carbs
i bet it runs real good :shock:
i bet he picked it up for $1800 and trying to triple his $$$
PostPosted: Thu Dec 18, 2014 10:45 pm
It must be a pos if the guy is already selling it. He could at least put air filters on it and pretend he cared about the Engine.
http://sacramento.craigslist.org/snw/4809981190.html. Anybody know why this Odyssey would have rear amber colored lights?
PostPosted: Fri Dec 19, 2014 12:42 am
Some old person owned it ???
PostPosted: Fri Dec 19, 2014 6:08 am
Lmao :-)
PostPosted: Fri Dec 19, 2014 5:30 pm
after looking at it it looks like he made it a bigger POS then it was before
whoever buys this is going to have problems
i can probably say that that Engine has been dusted more than once
1990 honda pilot FL400R 583cc rotax conversion with long travel
LT my ass maybe the front ?
$6000 obo
Rotax 583cc Engine is clean and installed professionally with recent service.
ha professionally
Everything on this buggy works from the lights to the transmission to the radiator. The conversion was done flawlessly.
$6000 obo
ha professionally
Custom long travel suspension
Disk breaks with steel braided break lines installed
New shocks and piggyback's from Honda.
Custom power block clutch with Spare belts
Custom exhaust mounted professionally with spark arrestor
ha professionally
Pull start and push start. Starts up everytime!
haha push start
Daniel
818-261-9zero9one
Daniel
818-261-9zero9one
PostPosted: Fri Dec 19, 2014 6:01 pm
You forgot the part about the breaks :-)
PostPosted: Tue Dec 23, 2014 7:52 pm
I could see him now, I will double my money on this thing LAUGHING my butt off. It must be something about that area, there is a guy on e bay tring to sell a well used pilot for 6K, then I said something to him in the line of your on drugs he wrote me back swearing he would get it now its at 5700 and I gave him the same line. About 3500 people will start to nibble on that 1. This one I don't think he will be able to give it away. I thought about it before for a project but 6K is INSANE
PostPosted: Thu Jan 22, 2015 2:06 am
Well I dunno if I should feel stupid or not but I bought this... Runs great handles very well just revs pretty high (4k) before it engages! Looking into getting the clutch tightened or springs replaced to correct it. Other than that some electrical such as kill switch and the starter needed to be re wired.
I'm into it for $3200 including purchase price a new battery and some electrical work! Is that bad? Lol oh well I'm enjoying it...
dimo
PostPosted: Thu Jan 22, 2015 3:45 am
dimo
4k is right where my 670 pilot clutch hits. that is the stock skidoo setting.
PostPosted: Thu Jan 22, 2015 11:26 am
dimo
Well if your happy with it that's all that counts.At one time he had this listed for 2200 then out of the blue jumped his price up to 6000! Hope it works out for you
PostPosted: Thu Jan 22, 2015 1:07 pm
dimo
Any recommendations on how to lower that a bit? I Know I'd be loosing power but id like to take off more accurately... Thnx
PostPosted: Thu Jan 22, 2015 1:10 pm
dimo
Thanks, I hope to get it to Glamis or Pizmo soon... I'd like to get it to engage alittle sooner because it has way to much torque off the line!
Dim
PostPosted: Thu Jan 22, 2015 1:12 pm
Dimo wrote:
dimo
Dim
Get a lighter spring?
Or heaver weights
This might help?
http://www.snowmobileworld.com/forums/a ... 58495.html
PostPosted: Thu Jan 22, 2015 4:39 pm
B S wrote:
Dimo wrote:
dimo
Dim
Or heaver weights
This might help?
Or just more throttle control, you should be able to get it up to 4K with 1/4 or less throttle, if you get it to engage too soon you may have a hard time getting it up on the pipe.
PostPosted: Fri Jan 23, 2015 12:34 am
I hope everything works out for you, that is more like it, it looked like some one bought it on the cheap and tried to stick it to some unsuspecting person. The price is much more like it. I thought real had about buying it till thaT 6000 PRICE TAG SHOWED ITS UGLY HEAD. Put some smaller tires on the rear, a 24 11 10 those looked gigantic and will take more to get rolling. Good luck
PostPosted: Fri Jan 23, 2015 8:57 am
The craigslist post are deleted so I wanted to make sure were talking about the same one.I had texted him when he had it listed without pics,this is when he was asking 2200.He sent me some pics.Its a different phone number then the one listed for 6000,so maybe someone bought it for 2200 then turned around and tried to get 6000 for it?
I don't know if anything is different from my pics and whet it was like when you got it.Is this it?
PostPosted: Fri Jan 23, 2015 6:25 pm
Looks like the high performance ATV front suspension with the rack and pinion steering to me.
Like to see more detail pics and see what they did to adapt the sled driven clutch to the Pilot input shaft.
No forethought given to the air box, gas tank and exhaust, typical no thought butcher conversion project bet it has 30% greater center of gravity than a stock Pilot .
PostPosted: Tue Jan 27, 2015 1:55 pm
Hey guys, I'm very happy with it!! Just got back from a weekend at Glamis and It did everything once I put some paddles on it. I have a video and will load pics shortly. In my opinion it's still got way to much torque right off the line. Hopefully when I post some pics one of you guys can give me a suggestion on how to get a better takeoff. Compression is at 140 in the left cylinder and 132-135 in the right I'm hoping a good carb cleaning, spark plugs and cleaning the fuel filter/ lines will correct that (Yes I know that's unlikely and I will probably end up changing the top end or one cylinder).
Also yes that's the one from the pics, it has K&N filters on it and all the metal on the a-arms, exhaust and frame was re painted with combination of red and black. A much bigger radiator and fan that my brother and I threw on there from a 94 civic lx. I'm going to change the fuel tank to aluminum one from ebay as soon as I find a good deal on one and finish this last tank.
PostPosted: Tue Jan 27, 2015 4:28 pm
I would replace the K&Ns for some uni foam filters and good sticky FFT oil, the K&N is fine for street or a boat but it will not stop the sand like a foam filter.
PostPosted: Tue Jan 27, 2015 11:50 pm
Either do like Kuma said, or wrap the K&N's in some black UNI bulk foam, then wrap that in some nylons. Make sure to oil the foam, and don't use UNI foam, it likes to drip off and doesn't stick to the foam. I use PJ-1, seems to work really well.
Some board members and i are planning on a Dumont trip for President's day weekend if you are interested.
PostPosted: Thu Jan 29, 2015 11:53 am
Got plans to go to Glamis for Presidents' Day but ic never been to Dumont... How do you like it? I heard the dunes are pretty steep!
PostPosted: Fri Jan 30, 2015 12:13 pm
glad you liked it. as long as you enjoy it and it is safe i say "let her rip tater chip!!!"
PostPosted: Wed Feb 18, 2015 9:50 pm
I love the power it has and the works suspension is great too! Only downside is the sled Engine has so much play before it actually takes off and it's torque is alittle much for the dirt trails... I'm starting to miss my fl400s nimbleness and handling... I may have it up for sale or trade for an fl400 soon
Here are some pics!
PostPosted: Thu Feb 19, 2015 2:26 am
Its all in the throttle control! My pilot has a 670 and the stall is 4k rpm. I trail ride it all the time and have no problems. I can take off without the slightest wheelspin. So either you aren't used to the throttle yet, or have other clutching issues! You should not have any problems with that 583, its a great Engine
