ddawkins4 wrote:
Thanks for the reply ODDY. I was also wondering if the FL400 rims and tires will fit on the fl350?
Here are the wheels that will fit on an oddy. Note that the Suzuki LT250R is the only one with the same rear pattern. Also the numbers at the end of the Bruin250 and the LT250R are the after market ITP wheels numbers. You still have to confirm the offsets on these wheels before you order or buy any of them.
I remember reading a thread that said the oddy front wheels could not be run on a pilot because of some clearance issue but you can run the pilot on the oddy front end.
TRX 200 90-93 & 96-97 Front 21x7x10 10×5 4×110
TRX 250 Big Red 86-87 Front 21x7x10 10×5 4×110
TRX 250X 86-87 Front 22x7x10 10×5 4×110
YFB 250 Timberwolf 2x4, 95-98 (F)22x7x10 10x5 4/110
Bear Tracker 250 99-09 (F)22x7x10 10x5 4/110
Bruin 250 05 (F)22x7x10 10x5 4/110 15R411 H154112
LT 250R QuadRacer 85-86 (R) 22x11x10 10x8 4/130 steel 18R411 Aluminum H184131
Odyssey 85-86 Front 21x7x10 10×5 4×110 Rear 24x11x10 10×8 4×130
Pilot 89-90 Front 21x7x10 10×5 4×110 Rear 24x11x10 10×8 4×130
