It is currently Wed May 14, 2025 7:50 pm
PostPosted: Wed Feb 15, 2017 10:56 pm
Looking for FL350 parts.
Shocks
Air box with boot
CDI (Capacitor Discharge Ignition)
Coil
Fuel tank and brackets
Brake Master Cylinder
Front fenders
The plastic pieces that cover the master brake cylinder on the steering column.
Might need some more later on but this is what I need for now.
Please send pictures with prices. Thank you.
PostPosted: Thu Feb 16, 2017 1:11 am
Shocks
Air box with boot
CDI (Capacitor Discharge Ignition) (Capacitor Discharge Ignition)
Coil
Front fenders
Some of that stuff will be hard to get like the brake master cylinder and plastic cover. When I get home later will post what to do.
PostPosted: Thu Feb 16, 2017 2:33 am
If you can't get a master cylinder you may have to do what jwhill did in this thread: viewtopic.php?f=5&t=11686&hilit=master
PostPosted: Thu Feb 16, 2017 2:44 am
Steering column cover, you may have to make one out of aluminum or sheet metal and rivets, similar to what was done here on page 2 : viewtopic.php?f=5&t=9382&hilit=steering+cover+aluminum&start=25
PostPosted: Thu Feb 16, 2017 2:45 am
The rest of that stuff you can get online but you may have an issue with finding a good none rusted tank with gas cap and key. Many put on those spun aluminum tanks but I am not a fan of that. I would go to a local plastic tank outfit and get them to make one out of plastic similar to the stock unit, a square L shaped tank. That's where I go to fix busted fenders. Had to do that so many times we no longer bother to run fenders. You don't need them if you put side skirts on to keep the crap out of your face from the front wheels.
PostPosted: Fri Feb 17, 2017 7:20 pm
Thanks for the reply ODDY. I was also wondering if the FL400 rims and tires will fit on the fl350?
PostPosted: Fri Feb 17, 2017 7:58 pm
Here are the wheels that will fit on an oddy. Note that the Suzuki LT250R is the only one with the same rear pattern. Also the numbers at the end of the Bruin250 and the LT250R are the after market ITP wheels numbers. You still have to confirm the offsets on these wheels before you order or buy any of them.
I remember reading a thread that said the oddy front wheels could not be run on a pilot because of some clearance issue but you can run the pilot on the oddy front end.
TRX 200 90-93 & 96-97 Front 21x7x10 10×5 4×110
TRX 250 Big Red 86-87 Front 21x7x10 10×5 4×110
TRX 250X 86-87 Front 22x7x10 10×5 4×110
YFB 250 Timberwolf 2x4, 95-98 (F)22x7x10 10x5 4/110
Bear Tracker 250 99-09 (F)22x7x10 10x5 4/110
Bruin 250 05 (F)22x7x10 10x5 4/110 15R411 H154112
LT 250R QuadRacer 85-86 (R) 22x11x10 10x8 4/130 steel 18R411 Aluminum H184131
Odyssey 85-86 Front 21x7x10 10×5 4×110 Rear 24x11x10 10×8 4×130
Pilot 89-90 Front 21x7x10 10×5 4×110 Rear 24x11x10 10×8 4×130
PostPosted: Sat Feb 18, 2017 9:49 am
I have half of the master cover if you are interested
Adam
PostPosted: Tue Feb 21, 2017 10:46 pm
I have a pen fuel tank sealed up on the inside. Not sure about the brackets though...
PostPosted: Wed Feb 22, 2017 11:08 pm
I have an airbox. Let me see what I paid for it, just want to get my money back if you're interested? Pics attached I was going to list it on eBay just haven't gotten around to it yet. PM me or I'll pm you once I figure out what I paid for it, then let me know if you're interested.
Mike
PostPosted: Wed Feb 22, 2017 11:13 pm
I also have stock front and rear shocks that aren't going to get reused. I will pull those out and get some pictures soon and message you directly. May get to it this weekend.
PostPosted: Fri Feb 24, 2017 8:50 am
This guy has 4 posts and hasn't been back for a week. I don't get these guys who ask for help and then don't have the courtesy to come back to their own post and respond. Maybe he has everything he needs but he should at least come back and thank everyone and let them know!
My 2 cents
