It is currently Mon May 19, 2025 6:21 pm
PostPosted: Fri Oct 06, 2006 6:48 am
Hello. Does anybody know if honda made a performance head for thier fl250. I got a guy claiming he has a head from a honda factory racer or some sort. It has v-fins, has small fins on the underside of it, it has a dome top internal, and only one spark plug hole. Any help appreciated thanks.
PostPosted: Fri Oct 06, 2006 6:51 am
I have seen them heads before I think they came off the MR250 or CR250 motor (( Internal Combustion Engine ? )) cycle that was design to make more power.
PostPosted: Fri Oct 06, 2006 9:22 am
'73 to '74 CR250 head is what it is.
MR250 heads are identical to the FL250 heads
PostPosted: Fri Oct 06, 2006 4:03 pm
Would it be worth it to get it for the price ($60 w/copper head gasket)? Or should I try to find another or just not worry about it. I just rebuilt the top end but a little more power can't hurt. Thanks.
PostPosted: Fri Oct 06, 2006 4:04 pm
PostPosted: Fri Oct 06, 2006 4:55 pm
i am not sure you will be able to notice the difference. You might want to make sure if the head has been shaved - you might want to cc the head - coming off of a racer it might be made for real high compression.
just a thought
PostPosted: Sun Oct 08, 2006 8:08 pm
I was suprised, I found this today on eBay.
http://cgi.ebay.com/ebaymotors/FL250-Od ... 0676QQrdZ1
