They are both BR9ES, one form the coil side and one form the PTO side.
Brand new plugs to start with and the plugs remover after a good ride out running around 1/3 to 1/2 throttle. The
Engine has now had about 5 tanks of gas through it.
Yes sorry that is not the best chose of words to describe the problem.
So shes a pain to start even with giving her 3 pumps from the primer. I find the best is to hold the throttle down 1/8 and crank it over until it catches and hope it revs up, then high idle her for a bit to clear the cylinders. The bogging happens then you go to pull away from idle. I have to be very gradual on the throttle for the first 1/4 if that and let the revs gently pick up. Then i can put my thumb down ones it had revved up a little ways and the Oddy has motion. If i'm to quick on the throttle from a stand still then its just bogs and will die.
Right i shall cut them off tonight and post some pictures. I really should take the jets and needles out to identify what i have to start with. I have also contacted Emmanuel form Farr Offroad quite a few times to ask about jetting and set up but i still have no response.
i like the look of the O2 sensor and shall look in to getting one of them, good call.
