It is currently Wed May 14, 2025 11:47 am
 Post subject: fl350 starter rebuild
PostPosted: Wed Mar 07, 2007 9:24 pm
Hey guys pulled my starter apart today and found lots of oil and gunk. I cleaned it up and took some pics. Never had one apart before so im not sure what its suposed to look like. before i order a rebuild kit what do you guys think? thanks
PostPosted: Wed Mar 07, 2007 10:26 pm
Hi and welcome to the site, their is some common problems with the FL350 starter and plenty of guys here to help you.
Here are some links I found on the starter to get you going until the experts chime in.
http://pilotodyssey.com/PO/viewtopic.php?t=2285
http://pilotodyssey.com/PO/viewtopic.php?t=2251
http://pilotodyssey.com/PO/viewtopic.php?t=2208
Some pictures Massody took of his starter http://pilotodyssey.com/cpg/thumbnails.php?album=10
Starter parts page from Randy at Odyssey Salavge.com
http://www.odysseysalvage.com/starter_parts.htm
Oil mod by Randy
http://www.odysseysalvage.com/fixstarteroil.htm
Here is the service bulletin Honda released years ago.
http://pilotodyssey.com/350sb.htm
PostPosted: Wed Mar 07, 2007 10:28 pm
Looks like the armature needs turned.
PostPosted: Wed Mar 07, 2007 10:44 pm
The armature needs turned for sure, unfortunetely you cant turn one of these very easy. The com is very thin and you cant cut it on a lathe. You should have the armatature put in a lathe and carefully sanded as flat from end to end and as round as possible without going through he copper.
If you install your new brushes on that armature they will wear much quicker then they should.
I am sure their is a local alternator and starter rebuilder in your town that would do it for a few bucks if you don't have access to a lathe.
PostPosted: Wed Mar 07, 2007 11:01 pm
ok i will look for a starter rebuilder and try to get that turned. that is the only way? could it be sanded? Now you say the brushes would wear quickly. what would quickly be in your opinion? 1 month, 1 year? supose it also determins how much i use it. thanks for the info..
PostPosted: Mon Mar 12, 2007 1:59 pm
Im in the process of taking off the bearing using the method that braintree used.question i have before i start is putting the new bearing back on..what are the tricks to that.
PostPosted: Mon Mar 12, 2007 5:01 pm
ironically I use my drill press as a poor man's press.
It slides on nicely if I use the chuck to press the outside of the bearing down.
Or I've used a socket that fits perfect and the drill press chuck to apply the pressure.
PostPosted: Fri Mar 16, 2007 2:49 pm
How you making out?
PostPosted: Fri Mar 16, 2007 5:07 pm
since i have a new starter in it hasnt been a big priority..hope to get to it this weekend.have to locate a puller to get that bearing off..that's one thing i don't have...been out tearing up the track and the fields around my property though..with this string of warm weather the boys wanted to get the quads out which means i was forced to get the odyssey out. pretty muddy :) got lots of pics! maybe ill post a couple this evening.
PostPosted: Fri Mar 16, 2007 6:29 pm
I picked up the puller from AutoZone, or whatever they are these days. I think most places like that and NAPA have the loner tools and you just give them a security deposit
