It is currently Sun May 18, 2025 5:20 pm
PostPosted: Wed Jul 25, 2007 11:01 am
Went back to Northam Speedway 22-7-07 and had good luck and bad! Good luck,got 1st and 1st then was going good in 3rd race till motor (( Internal Combustion Engine ? )) died on me. :shock: Drats n double drats! Actually I said !@#$% n %$#@!Stopped in the middle of race track, close to the exit, so that was handy anyway. Pulled on the rope, and zero Comp! :shock: Pushed it back to pits, and did comp test-0 psi :shock:
The track driving conditions are the worst I have ever driven in my life! The mud there is a sticky clay type, the sort brickmakers n clay modellers use. It sticks like dog bog to axminster! :shock: Must have had an extra wheelbarrow amount of the stuff on the Pilot, gettin heavier n heavier-like gettin older n fatter! :shock: :-) Lots of drought breaking rain all week leading up to the race day.
Anyway, removed plug n exhaust pipe to check colour, white-light grey! with white bits! Dry,used to be black,n obviously leaned out. Made up adapters today for leak test and found hissing noise while pumping up!.Remember not far back one of the guy's here had the leak from right rear cyl-crankcase nut area? So's mine. Will dismantle top end tomorrow and take pics. Question time! Would this air leak have caused the meltdown?(have hole in top of piston crown?) thus resulting in the depowering of the fuel pump,or have been a legasy of it leaning out and geting hot? The temp light did not come on the steering wheel.
Anyway here's some pics n vids. On the wine at the moment, raining here in West Aus, I think trhe wine's startin to kick in! :shock: :-)
http://www.youtube.com/watch?v=YuHRJWko8Kk
http://www.youtube.com/watch?v=d1danByrUCs
http://www.youtube.com/watch?v=BzjmtmVzaKk
http://www.youtube.com/watch?v=uDhwNTx446s
http://www.youtube.com/watch?v=QwYHVkOLsVk
PostPosted: Wed Jul 25, 2007 11:22 am
Yeeh Harr! Well done! Still don't know why they would'nt work from my end, but you came thru,as usual :-)
What do you think is the reason for holed piston,lean-out? The pilot was working hard! The clay must have been a burden to go thru,like draggin an anchor,especially at race pace,high revs-low labouring speed,lessened air flow.Day temps were cool to cold and windy.25:1 oil mix,40mm/Ltr.Mud plugging up vent tubes? Cyl base gasket lettin go, plus hindering the vacuum fuel pump, resulting in less fuel delivery?
Whatever it was, I had a blast, and was definately lapping faster, against the higher powered buggies. The Pilot really is a Wolf in Sheep's clothing, it pisses off a lot of weekend warriors here!hehe!I have noticed that the worse the conditions are, the more it favours the Pilot.If you watch the vids, we were going at snails pace up the inclines strugglin for traction. Would have been better off with Nukem's Paddles to power on thru the mud crud! :-)
PostPosted: Wed Jul 25, 2007 11:26 am
Forgot to mention:
The new Nissan Navara (Frontier? USA) was a pleasant surprise! :shock: :-)
Plenty of Up-hill grunt,roomy,nice sound stereo,and THAT quiet! I could actually here everything that me and the family were arguing about! :-)
PostPosted: Wed Jul 25, 2007 11:27 am
I have no idea on the poofkaboom at this point I will have to wait and see the autopsy results, I know more load requires more fuel so the loads of the mud may have played a part.
PostPosted: Wed Jul 25, 2007 11:39 am
Thanks to you and your site Hoser! What ive already done and planning to do is all from what ive learned from this site and everyone's pics and input cannot be over emphasisiesed! Now I'm pissed! Can't even spell Emphasisied :shock: :-)
I'm off to bed! Good Night from Downunder! :-) ...Baz
PostPosted: Wed Jul 25, 2007 12:37 pm
No problem! I sure wish I knew what the problem is...
How long are your race heats? You go by laps or by time?
PostPosted: Wed Jul 25, 2007 7:04 pm
Races are 4-6 laps,timed.
Just managed to load this pic,will try rerun.
PostPosted: Wed Jul 25, 2007 7:06 pm
another
PostPosted: Wed Jul 25, 2007 7:35 pm
Did'nt work again,with pics.
Will try this text without pics.
THIS SUX!
Righty ho then! Seems to work only without pics! :shock:
PostPosted: Wed Jul 25, 2007 7:54 pm
THIS SUX!
Send me the pics that didnt go or try to resize slightly with the resizer http://pilotodyssey.com/PO/viewtopic.php?t=3227
PostPosted: Thu Jul 26, 2007 2:24 am
pics Test
PostPosted: Thu Jul 26, 2007 2:29 am
test
PostPosted: Mon Jul 30, 2007 6:45 pm
pics Test
Covered in mud you can see how well of a job you have done with your bonnet!!!
pics Test
PostPosted: Mon Jul 30, 2007 7:02 pm
G'Day David, yeah the Baz Bonnet works good,still needs a few mods, but worth the effort.
This mud tho,is a real pain in the !@#$! It sticks!!!! Takes about 2 hours of hosing,brushing,proding etc.
I'll be spraying the Pilot next time with a Silicone spray,to make it easier to hose off next time.
My ol' mechanic said that he used to spray his bikes with a mixture of Diesel, and ol sump oil.
PostPosted: Mon Jul 30, 2007 7:05 pm
The diesel will really help.. I used to use WD 40 on my shoes when I had to work in mud....
PostPosted: Mon Jul 30, 2007 7:33 pm
Try your ordinary old household cooking oil spray, PAM.
I've been using it for 25 years, it's cheap and works great.
Works good even in brush and prevents most scratches.
