It is currently Thu May 15, 2025 9:21 am
Post new topic Reply to topic  [ 247 posts ]  Go to page Previous  1, 2, 3, 4, 5 ... 10  Next
PostPosted: Wed Jul 15, 2009 8:02 pm
Im jealous, keep the pics coming!
 Post subject: FL350 restore
PostPosted: Sun Jul 26, 2009 9:23 pm
Hello everyone, here are some pics of where I am at as of today.
Going slow but smooth, getting very close to having to do the wiring harness.
File comment: Recoil starter, took it apart and cleaned + lubricated it.
File comment: Steering column has all new bushings + new steering shaft.
File comment: For some reason I did not take a picture of this area before disassembly, had I lot of fun routing the cables. If this looks wrong please let me know.
File comment: Finally the motor (( Internal Combustion Engine ? )) is in, tight fit. I will have to touch up a couple of spots with paint.
PostPosted: Sun Jul 26, 2009 9:26 pm
More pics.
The connector bracket by the gas tank went in fine backwards.
PostPosted: Sun Jul 26, 2009 9:28 pm
More pics.
PostPosted: Sun Jul 26, 2009 9:30 pm
More.
PostPosted: Sun Jul 26, 2009 9:31 pm
Last two for now.
PostPosted: Tue Jul 28, 2009 3:35 pm
wow looks great. I need to get myself some of that gold paint ...
PostPosted: Tue Jul 28, 2009 6:03 pm
Definately a thing of beauty, your going to cry the first time it gets scratched, I will. Very impressive work, can't wait to see the finished product.
Gary
PostPosted: Fri Jul 31, 2009 9:41 pm
Im inspired to tear mine back down now and redo it like you lol. Very nice im going to try to hold off till winter hits.
PostPosted: Sat Aug 01, 2009 8:54 am
Nice looking head on that motor- :-)
 Post subject: FL350 Restore
PostPosted: Sat Aug 01, 2009 9:02 am
Good day to all, hopefully I will have a rolling chassis by tonight putting the left rear suspension together today.
I think I have just about put off the wiring harness as long as I can, should be starting on it tomorrow I am adapting an 89 pilot wire harness.
Starting to look like a machine.
Thank you everyone for all your reply's very kind.
PostPosted: Sat Aug 01, 2009 9:04 am
Yes some really nice guy helped me to get it, how are you doing Mudbogger.
Did you ever get your switches from service honda.
PostPosted: Sun Aug 02, 2009 5:29 am
Hi there, no they haven't arrived to date here-
PostPosted: Tue Aug 04, 2009 9:04 pm
Hello and good evening to everyone.
Here are some pics of where I got to on Saturday, my wife kept me home on Sunday so a rolling chasis is as far as I have gotten.
File comment: Learned a lesson on the radius arm heims joints, had them all greased and ready to go but when I tightened the nut down the joint kept turning to the side. Ended up taking the boots back off, cleaning all the grease back out and reinstalling them dry.
File comment: Torqued the nuts down with no boots or grease so I could hold the joint centered, then installed the boots and grease.
File comment: Belt cover freshly painted.
PostPosted: Tue Aug 04, 2009 9:13 pm
More pics.
File comment: It rolls it rolls.
PostPosted: Tue Aug 04, 2009 9:17 pm
Last set for now. I will not be able to get back to work on it until weekend after next.
PostPosted: Tue Aug 04, 2009 10:04 pm
I am really looking forward to the Pilot wheel and wire harness you'll be running on this ody, that's a mod for the ages indeed, the wheel alone if you use the masters IMO is a great upgrade, along with the fuel sensor too.
Steve, could you please detail that install and mods(if any) for us 350 gurus-Nuke-Em would be so happy like me to see that-thanks!!!
PostPosted: Tue Aug 04, 2009 10:41 pm
Good evening, you bet I will get more detail on the wheel and wire harness as I do it.
What I did when I set the spot for the fuel level sensor is, I filled the old tank that came out of it with 1/2 water and then marked the outer part of the tank all the way around. I then reinstalled it and figured out the safest location for the sensor, I drilled and had a nut saudered in place before I had the new used tank double lined. The guys that do my radiator's did the sauder and lining for free for me and they really did a good job.
The sensor is about half a tank give or take a little.
There is a better way to do this and it would make use of some old pilot tanks that are no good, in the pilot fuel tank where the level sensor goes in it has a tube for the sensor that keeps it from going off when fuel is sloshed around.
If I had a pilot tank to cut up I would have much rather done it this way.
I used the pilot rear brake caliper for many reasons, it has the return spring that is much stronger than the odyssey's,
it has a brake wear indicator and it's arm has the hook up for the brake light switch.
The steering wheel is going to be the easiest I think and hope, the biggest thing is getting longer brake hoses and securing the metal lines so they do not move around. The master's are the main reason I am using a pilot wheel, that idea is what started the whole thing with the harness and everything else.
Have a great night.
PostPosted: Tue Aug 04, 2009 11:16 pm
beautiful showroom job!!!! I wish I had your patience and skills!!!
PostPosted: Wed Aug 05, 2009 9:12 pm
Everytime i see these pics i get a strange feeling in my pants.
PostPosted: Wed Aug 05, 2009 9:27 pm
PostPosted: Wed Aug 05, 2009 9:28 pm
Thank you turbo, very kind.
PostPosted: Wed Aug 05, 2009 9:52 pm
scpilot66 wrote:
You are welcome, and I think the strange feeling comment was too a compliment!!! LOL
PostPosted: Thu Aug 06, 2009 8:40 am
yes its a compliment lol
PostPosted: Thu Aug 06, 2009 8:46 am
Thank you, I took it as a compliment. Just caught me off guard.
