It is currently Thu May 15, 2025 9:42 am
Post new topic Reply to topic  [ 247 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6 ... 10  Next
 Post subject: FL350R Restore
PostPosted: Tue Sep 01, 2009 9:36 pm
Hello to all, I have been working alot lately so work on the odyssey has been slow.
Here are pics of where I am at as of this last Sunday.
File comment: Pilot steering wheel just painted.
File comment: Ok I know that this will all seem simple but I went crazy figuring out where the best place was for the pilot fuse boxes.
This is a motor (( Internal Combustion Engine ? ))/ trans. bracket cut in half and bent in a U to mount to where the pilot starter relay used to mount.
File comment: The Fuse boxes and bracket are from a 1989 Pilot
PostPosted: Tue Sep 01, 2009 9:51 pm
More pics.
File comment: Cut the mounting point off of the pilot fuse box bracket but left enough for the fuse box hold down to be put on later.
File comment: Had to cut down the old odyssey starter relay mount, needed the pilot relay mount to set back all the way against the battery box.
File comment: Had to cut the top and sides of the hinge down.
File comment: Fuse box bracket mounted.
PostPosted: Tue Sep 01, 2009 9:54 pm
More.
File comment: Fuse boxes mounted.
PostPosted: Tue Sep 01, 2009 9:57 pm
More.
File comment: Only took me half a day to figure out this spot.
File comment: Both Pilot and Odyssey harnesses.
PostPosted: Tue Sep 01, 2009 10:00 pm
Wow that is sharp, nice fabbing. Lookin good!!
PostPosted: Tue Sep 01, 2009 10:05 pm
More.
Thank you Stix, much appreciated.
File comment: Many wires will have to be moved and added. Stripped down both harnesses, no cutting all unwrapped.
Pilot harness.
File comment: Odyssey harness pieces I cut out to use.
File comment: What's left of the Odyssey Harness.
File comment: Pilot Harness laid out.
PostPosted: Tue Sep 01, 2009 10:35 pm
Last set.
File comment: Check/Timer Unit, another fun thing to figure out where to put it.
PostPosted: Wed Sep 02, 2009 6:19 am
Looking really good, the head looks like something Honda would have made.
 Post subject: fl350r restore
PostPosted: Wed Sep 02, 2009 9:35 pm
Thank you Hoser, I appreciate it very much.
PostPosted: Wed Sep 02, 2009 10:06 pm
that head makes the machine.very nice work
 Post subject: FL350R restore
PostPosted: Fri Sep 11, 2009 9:58 pm
Here are some pics of where I got to last weekend.
I could not stand it so I took a break from the wiring and put the steering wheel on and assembled part of it.
File comment: Pilot wheel, I had a lot of fun painting this.
SNC10177.JPG [50.29 KiB]
Downloaded 401 times
File comment: Brand new rear master.
SNC10178.JPG [43.72 KiB]
SNC10179.JPG [57.5 KiB]
File comment: Brand new front master, I got this from pilotpete.
Thank you Pete.
SNC10181.JPG [46.11 KiB]
PostPosted: Fri Sep 11, 2009 11:04 pm
Ok Wiring.
I have decided to use the odyssey regulator, it will be better wiring wise. Less splices.
The one big difference between the odyssey and the pilot wiring is on the 1985 Odyssey FL350R there are 4 wires coming from the ignition switch, 1 power in, 1 power out, 1 ground in and 1 ground out, ground is applied when the switch is off and power with key on. The pilot switch also has 4 wires but 2 power in and 2 power out, both powered key on.
The main thing this boiles down to is on the odyssey ground is applied to the CDI (Capacitor Discharge Ignition) to shut the motor (( Internal Combustion Engine ? )) down through either the run or ignition switch. On the pilot power is taken away from the CDI (Capacitor Discharge Ignition) to shut the motor (( Internal Combustion Engine ? )) down through either switch. The wire is black and white on both machines
To use a pilot ignition switch you would have to run a ground through a toggle switch to the CDI (Capacitor Discharge Ignition) to shut the motor (( Internal Combustion Engine ? )) down.
I have decided to use the odyssey switch, I am going to add a relay for the second power source.
The only bad thing is, from the factory either the ingnition switch or run switch will shut the motor (( Internal Combustion Engine ? )) down on both the pilot and odyssey. With this setup the motor (( Internal Combustion Engine ? )) will only be shut down with the key, I might add a toggle switch on top of the ign. switch. Not sure about that yet.
Have a great weekend everybody.
File comment: Starting point, going to run the harness around the roll cage instead of under the motor (( Internal Combustion Engine ? )).
File comment: I will extend the power and starter wires first. The ground wire will be bolted to the belt cover mount.
File comment: Used heat shrink connector's with sealer and then used heat shrink tubing with sealer.
SNC10175.JPG [40.06 KiB]
Downloaded 388 times
File comment: Starter and power wires extended and taped.
SNC10176.JPG [35.58 KiB]
File comment: Odyssey wire harness parts to use.
SNC10183.JPG [60.9 KiB]
 Post subject: FL350R restore (Wiring)
PostPosted: Fri Sep 11, 2009 11:47 pm
Pilot harness showing timer, coil, CDI (Capacitor Discharge Ignition), regulator and tail light plugs.
 Post subject: fl350 wiring
PostPosted: Sat Sep 12, 2009 12:03 am
The 2 wire and 4 wire pilot CDI (Capacitor Discharge Ignition) plugs are not needed, the odyssey harness parts used will take the place of these.
The 2 wire plug, gray wire was to the reverse switch and CDI (Capacitor Discharge Ignition), disabled. The black and white wire was the power wire to shut the CDI (Capacitor Discharge Ignition) down on the pilot also not needed. I am going to use the black and white wire for my water pump power, it is key on power.
The 4 wire plug, black and yellow-coil, blue and yellow-pulse, yellow-alternator, green-ground. I will use the odyssey harness parts I cut out in place of this harness.
I have taken out the gray and black fuel sensor wire section that went to this plug and will tap back in to it at the timer unit for the fuel sensor hookup.
SNC10185.JPG [33.04 KiB]
Downloaded 377 times
PostPosted: Sat Sep 12, 2009 12:10 am
On the pilot harness I will use the old coil ground for my fuel sensor ground, the odyssey harness parts cut out have the coil ground on them.
I cut out the pilot regulator plug and will extend the wires to tap in to the odyssey regulator harness parts.
Green to green ( ground ), black to black ( ignition power ), Red to red and white ( battery power ).
When I cut the odyssey harness parts out that I needed I was careful to leave the CDI (Capacitor Discharge Ignition), regulator, coil, alternator, pulse generator and grounds part of the harness as complete as possible.
I am going to cut out and use the old pilot black and yellow coil wire for the fuel senor, I will splice it in to the gray and black wire at the timer unit.
SNC10187.JPG [36.26 KiB]
Downloaded 375 times
 Post subject: FL350 wiring
PostPosted: Sat Sep 19, 2009 10:21 pm
Hello to all, this is where I have gotten to as of last weekend.
File comment: Odyssey harness parts I cut out to reuse.
SNC10166.JPG [38.09 KiB]
Downloaded 309 times
File comment: I will splice the red, black and green to the same red, black and green of the pilot harness.
SNC10167.JPG [36.37 KiB]
File comment: Odyssey harness on machine to splice in to pilot harness.
File comment: Zip tied harness to frame for splice in's. Red wire is battery power to regulator.
File comment: Black wire is ignition power to regulator.
SNC10175.JPG [48.69 KiB]
PostPosted: Sat Sep 19, 2009 10:32 pm
I did not have exact wire colors in some spots but the gauge is the same.
File comment: Extending check unit wires + added fuel sensor wire, spliced in to gray and black wire.
File comment: Wire's spliced in.
SNC10181.JPG [52.24 KiB]
Downloaded 305 times
File comment: Extended tail light plug, I will be using a pilot tail light.
PostPosted: Sat Sep 19, 2009 10:53 pm
Regulator, alternator, pulse generator, CDI (Capacitor Discharge Ignition), coil, check unit, fuel sensor, grounds and tail light all extended and spliced in.
The original odyssey wire harness has a ground that bolts to the roll cage at the top right air dam mount bolt, I left that one and added a second one to the left top air dam mount as well.
I left the odyssey black and white wire to the CDI (Capacitor Discharge Ignition) fully intact and have ran it along the whole pilot harness to hook up to the odyssey ignition switch. The odyssey CDI (Capacitor Discharge Ignition) is grounded thru this wire to kill the motor (( Internal Combustion Engine ? )).
The pilot harness, same black and white wire also goes to the CDI (Capacitor Discharge Ignition) on the pilot but it is powered not grounded. I was going to use this wire to power my water pump but it is not heavy enough gauge, I have just pulled it out of the harness but not cut it at this point. If I can not figure out something to use it for it will be removed.
SNC10187.JPG [32.37 KiB]
Downloaded 300 times
File comment: This section ready to be heat shrunk.
SNC10188.JPG [41.8 KiB]
PostPosted: Sun Sep 20, 2009 12:50 am
Nice work on the odyssey, great job on the wiring, can't wait to see it all done.
Bob
 Post subject: FL350 Restore
PostPosted: Sun Sep 20, 2009 8:20 am
Hello Bob, thank you very much.
 Post subject: Brakes
PostPosted: Wed Sep 30, 2009 1:30 am
Before doing the wire harness to the steering column switches I am finishing the brake connections at the steering column.
File comment: A friend of mine welded on the bracket for the brake hoses.
File comment: Did not want to but had to cut the original brake cable mounts.
File comment: Cover fits with no problem.
SNC10175.JPG [44.79 KiB]
Downloaded 240 times
 Post subject: Brake lines
PostPosted: Wed Sep 30, 2009 1:37 am
On the odyssey the rear brake line is on the right side of the steering column and the front is on the left, the pilot is the opposite.
I could either cross the hoses off of the steering wheel or cross the brake lines, crossing the brake hoses is easier but I chose to cross the lines. I think it is better.
File comment: Hoses crossed.
SNC10176.JPG [39.85 KiB]
Downloaded 239 times
File comment: Lines crossed, this is the way I am going.
PostPosted: Wed Sep 30, 2009 5:52 pm
Steve, could you list the part numbers for the fabbed pieces between the rubber and stock lines?
Are they metric 10mm to standard threads?
 Post subject: brake lines
PostPosted: Wed Sep 30, 2009 6:25 pm
They are 3/16 line with 10mm by 1.0 fittings, I had to buy long lines and cut them down + reflare.
I will get the part # for the fittings, I had fun tracking those down.
All metric 10mm by 1.0 thread.
PostPosted: Wed Sep 30, 2009 8:03 pm
I like the pilot wheel conversion. Im doing the fl350 wheel conversion on my fl250 since I put brakes on the front. Ill have to make a thread on that as soon as all my parts come in.
Registered users: Google [Bot], Lanix, wyeeoddy
