It is currently Mon May 19, 2025 4:50 am
PostPosted: Tue Apr 20, 2010 9:26 pm
I just got my DG pipe installed and would just like to know what jet combinations I should start with. Its a 350 stock carb, stock bore, water cooled head, stock air box. Any help would be very thankfull. Oh and thanks Tpreed for the exhaust manifold :-)
PostPosted: Wed Apr 21, 2010 2:11 am
depends on a lot of other things. I forget what was in my stock carb, but I have a 160 main in my 39mm, and it runs a little rich. I would just do a couple plug chops to get in the ballpark and then keep an eye on your plugs.
PostPosted: Wed Apr 21, 2010 7:29 pm
nobody out there running a simular set up? just looking to get in the ball park. I don't have much experience with carb tuning, and the odyssey came with several different jets. Just thought maybe someone could save me a lot of time.
PostPosted: Wed Apr 21, 2010 8:17 pm
I don't know what you should start at because I run a mikuni carb, but just start rich (biggest jet you have)and do plug chops and slowly lean it out.
PostPosted: Wed Apr 21, 2010 9:33 pm
I would start with the biggest jet you have and work down. There are too many environmental factors that effect jetting, even with a similar setup. Air temp, elevation, barometric pressure and humidity all effect your jetting.
PostPosted: Wed Apr 21, 2010 9:35 pm
how about moving the clips up or down on the main?
PostPosted: Wed Apr 21, 2010 9:49 pm
I would set in the center position and leave it there. You don't really want to mess with the clip until you find the right main jet.
PostPosted: Thu Apr 22, 2010 11:36 am
Hmm
Where is Mudbogger he has setup how many of these now?
How is your jetting skills?
Have you read this?
http://pilotodyssey.com/BillGivensjetting.htm
Anybody new to jetting should print that out and read it a few times, give a day or two to soak in between reads, jetting is not hard once you learn it you can diagnose and jet like a pro.
