It is currently Wed May 14, 2025 6:24 am
Post new topic Reply to topic  [ 46 posts ]  Go to page Previous  1, 2
PostPosted: Sun May 02, 2010 11:09 pm
PM sent
PostPosted: Sun May 02, 2010 11:43 pm
i BOUGHT SOME RINGS OFF FLEA BAY GUY SAID THEY WERE .25 350, BUT THE LAST 3 NUMBERS DON'T MATCH???
I have 13012-VMO-681??? Service honda site went haywire when I typed this in... Anybody have an idea on what these are???
First coice would be to see if you can still get the Honda piston.
Here is the honda part numbers, first try to get the .25mm
13012-VM0-305 RING SET, PISTON (0.25)
13102-VM0-315 PISTON (0.25)
If they cant get the .25mm then try to get the .50mm here is the numbers for the piston and ring.
13103-VM0-315 PISTON (0.50)
13013-VM0-305 RING SET, PISTON (0.50)
With either set you get you will also need the wrist pin, wrist pin bearing and the circlips those numbers are below.
13111-KA4-770 PIN, PISTON
91015-KZ3-003 BEARING, CONNECTING ROD SMALL END
90601-430-000 CLIP, PISTON PIN, 1.2X18 (NEED TWO OF THESE)
PostPosted: Mon May 03, 2010 12:03 am
They are 25 over and I believe they were once part of a complete piston, ring, circlips kit. I have a few sets of those myself
Oh, and they do come up on service honda's page, you need to use VM0 "V" "M" "ZERO" not the letter "O" and they're $28.88 a set
PostPosted: Mon May 03, 2010 11:04 am
Greg said he had a piston, but no rings for me. Would anybody else have what else I need and be willing to sell? Or a complete set either?
JP
PostPosted: Mon May 03, 2010 9:11 pm
theres a set on ebay, not sure what size though
http://cgi.ebay.com/ebaymotors/FL350R-O ... 25562572c9
I have a set for an 80mm piston and they are part number 13012-vmo-003
PostPosted: Thu May 06, 2010 3:40 am
Hoser, I got a piston set for .25 over...need me to ship that to you as well??
JP
PostPosted: Thu May 06, 2010 9:22 am
JP
Yes I need the piston so I can bore the cylinder.
PostPosted: Thu May 06, 2010 12:20 pm
It should be in today or tomorrow, so I'll ship out ASAP.
PostPosted: Fri May 14, 2010 5:42 am
Just wanted to double check that the piston came in good health?
PostPosted: Fri May 14, 2010 11:28 am
Yeah its here hopefully I will be putting the finishing touches on it today :-)
PostPosted: Sat May 15, 2010 6:37 am
Awesome! Thanks for all your help Hoser!
JP
PostPosted: Mon May 17, 2010 5:13 pm
Ok your cylinder is done, their was some really ugly casting flaws on this thing I could not allow them to remain in place choking your Engine every time you run it, so I spent a little time and knocked all them down smooth them out and blended them in, the piston was prepped and I drilled the cooling/lube holes for you.
PostPosted: Mon May 17, 2010 5:17 pm
Your cylinder bore was not cleaned you will need to clean it, I got out my refillable lubricator and filled it with Engine oil then sprayed the cylinder down good so their is no way it can rust, its a new policy in my shop I am not taking any chances after seeing GarlicGreg's cylinder, that has never happen and I want to ensure it will never happen again, I never did figure out what caused it to rust like that, nothing in my shop is rusting like that either.
Sorry for the mess
PM me your address again I will ship it right out to you.
PostPosted: Wed May 26, 2010 5:28 pm
Got it in the mail last week. Looks good! Now I just gotta get some time to work on the damn thing. Shift work sucks!!
Thanks for the help Hoser
PostPosted: Wed May 26, 2010 5:58 pm
NP
Be happy your working :-) been their done that on the shift work gets old fast..
PostPosted: Wed May 26, 2010 9:18 pm
Turns out the Honda dealer that I ordered my rings from did NOT have any. So if any of you have a set that you didn't use I would buy them from you. I need a set for the Honda .25 over piston.
PostPosted: Wed May 26, 2010 9:30 pm
Also what gasket setup do you all recomend for the top end? I found a couple auctions on eBay both for vesrah and cometic.
PostPosted: Wed May 26, 2010 10:00 pm
My preference would be
1. OEM
2. vesrah
3. cometic
PostPosted: Thu May 27, 2010 2:19 am
GOOD aluminum OEM base gasket!
http://cgi.ebay.com/ebaymotors/honda-fl ... 414fdc517c
PostPosted: Sun Jun 06, 2010 11:02 pm
Still looking heavily for some .25 rings!! :-)
PostPosted: Mon Sep 17, 2012 10:22 am
Bump to the topic still in the "For Sale/Wanted" area.
http://www.pilotodyssey.com/PO/viewtopic.php?f=4&t=7354&start=50
Last bumped by hoser on Mon Sep 17, 2012 10:22 am.
