It is currently Wed May 14, 2025 12:41 pm
Post new topic Reply to topic  [ 65 posts ]  Go to page 1, 2, 3  Next
 Post subject: .25 rings for FL350
PostPosted: Thu Jun 03, 2010 3:52 pm
I've been trying to keep an eye out on eGay but haven't had much luck. My local dealer said they could get these rings (surprisingly).....but as I soon found out they actually couldn't.
That being said I'm on the lookout for a set of rings to get this thing going. Hoping maybe somebody here would have a set that they didn't end up using.
Thanks,
JP
BTW my number is 405-880-6992
e-mail paige.jonathan@gmail.com[/i]
PostPosted: Tue Jun 08, 2010 8:33 pm
Bump^^^
It would be sweeeeet if I could get this back together! :-)
PostPosted: Wed Jun 09, 2010 3:12 am
You could get wiseco rings from denniskirk last I checked ...
PostPosted: Wed Jun 09, 2010 8:41 am
Wiseco rings wont work on a OEM piston
PostPosted: Wed Jun 09, 2010 9:47 pm
Well I guess I should share some info . First let me say I have not tested this or ran the combo.
Story time first. Stix and I was talking one day about this same thing. I had a brain fart and said knowing honda and how they like to keep things the same I said for the fun of it let put a set of pilot rings on the 350 arts piston. The Brain fart test was on an older bore so the number were kinda hard to interpolate by I came up the conclusion that they ______. I said ( to stixs) lets just look at the part numbers.
First look at the part # UM
350: 13012-VM0-305 RING SET, PISTON (0.25)
400: 13012-HE0-305 RING SET (OS) (0.25)
Let's see does wiesco use the same ring for the 350 and 400 ?
350: 3150TD - 80.00 MM RING SET
400: 3150TD - 80.00 MM RING SET
See where Im going, VMO/HEO, I see a pattern
Ok not to keep you quessing. They _______ I still need to so some number crunching before test was warrented but dry fit gaps and Other factor told me to go ahead and test. The test would have been done firs to bore/hone the cylinder tight to the new piston.
CAUTION,
The 350 piston is to be measured at 20mm from the skirt and the pilot 10 mm from the skirt for sizing according tp the book. Well me being me I measure up the hole thing then go from there for piston fitting. After determining the minium clearence ect.,bla,bla,bla. I would bore and hone to that number.
I then would set the rings in and check gap log number and do some math to deterine if it was plosable to proceed.
I did factore in the piston land pins ( rings, locking pins) and Stixs and I measured the taper,depth and dia. and siad why not. We fitted a set of older 400 .25 rings into the new .25 arts Domed ( not flat top) piston and looked good.
The next step is to get my hands on a new set both for VMO and HEO and compare. Sad news here stix sold his 350s.
So who going to find out for sure. The prelimbanry data shows they will work. This will allow the 350 guys running arts chang rings sooner and get more time out of the pistons and yes keep it fresh and fast.
"H" being "H" he has alrredy done work and knows the anaswer.
Any way thought I would share What Stixs and I was thinking of. If some one wants to run with it, here is some pics.
File comment: stock piston ring taper
pilot ring taper ( honda ring ).jpg [55.95 KiB]
Downloaded 145 times
Taper (old ring will not reuse do not twist like this).jpg [ 94.32 KiB | Viewed 2101 times ]
Thick side of ring taper (old ring).jpg [85 KiB]
PostPosted: Wed Jun 09, 2010 9:51 pm
more pics
End gap in bore ( old bore) at top for best measurment.jpg [ 121.24 KiB | Viewed 2009 times ]
PostPosted: Wed Jun 09, 2010 9:57 pm
more pics
File comment: Standard .45 to .60 mm
Note: service limit 70mm
Ring groove thickness ( old piston) outside edge.jpg [76.67 KiB]
Downloaded 142 times
Ring grove depth step 1.jpg [81.87 KiB]
Ring groove depth #.jpg [92.65 KiB]
PostPosted: Wed Jun 09, 2010 10:00 pm
It would not surprise me if the 350 and Pilot rings were the same for each bore size on the OEM pistons their is really no reason why they would be different is their? You measure the grooves in the piston and measure the depth of the rings as they would fit into the grooves of the piston?
more pics
checking bore dia for ring gap comparison and psiton to bore clearence.jpg [ 85.49 KiB | Viewed 2095 times ]
PostPosted: Thu Jun 10, 2010 4:51 pm
I guess the part number should have clued me in that he was after OEM rings ...
PostPosted: Thu Jun 10, 2010 7:26 pm
Good post Adnoh. This wil help a lot of guys. I know we measured and discussed but I could not remember if it was confirmed. Thanks for clearing it up for us!!
PostPosted: Thu Jun 10, 2010 7:29 pm
Yeah I am going to move it to the tech section before too long.
So he can just order some Pilot rings??
PostPosted: Thu Jun 10, 2010 7:59 pm
Hey "H" , if they work, I'm not 100% sure yet. Have some concerns and want to be cautious telling other to do it. Discuss more in other topic location.
PostPosted: Thu Jun 10, 2010 10:22 pm
I would be willing to "take one for the team" If Hoser wouldn't mind!
I am Buying a jug and art piston from Styx... And I already have a set of rings for the .25 over I stumbled upon on Fleabay... So I would buy the pilot rings and when hoser puts my 350 motor (( Internal Combustion Engine ? )) back together we could have him look over everything and decide if it's worth the effort... And of course ya'll have seen how much testing it would get!
PostPosted: Thu Jun 10, 2010 10:24 pm
This would be sweet! I've been checking all the local stores in the surrounding towns, and still having no luck. I just wanna ride!! :-)
PostPosted: Thu Jun 10, 2010 10:28 pm
I would want to hang on to the 350 rings until Hoser can side by side them and make a decision... I hope I didn't get your hopes up... Keep scouring e bay... I just stumbled across them one day...
PostPosted: Thu Jun 10, 2010 10:30 pm
I've been keeping a keen eye out.... I'm definitely not new to the hassles of finding parts for "quality aged" machines. hehe
PostPosted: Tue Jun 29, 2010 8:07 pm
Any new updates on the .25 Pilot rings?
PostPosted: Sun Jul 04, 2010 2:05 pm
Yep. I had the privlage of looking over both yesterday and the oly thing I could see is the color diffeence in the steel. I suspect a set of ring going up on ebay real soon. Yea the stock fl350 rings. If they fit your piston no idea. I have not used of tested so no help there. Who knows yo may just get a p.m. from the owner. Wish ya luck.
PostPosted: Sun Jul 04, 2010 9:55 pm
I'll be the guinea pig if I get a set! :-)
PostPosted: Wed Jul 28, 2010 2:08 pm
bump??
PostPosted: Wed Jul 28, 2010 7:26 pm
Heres the owner. Sorry I try to read every post here but... I have the .25 over for the FL350. Do you want to try them?
PostPosted: Thu Jul 29, 2010 12:28 am
I desperately need a set for my FL350. How much would you be willing to part with them for?
-JP
PostPosted: Sat Jul 31, 2010 5:53 am
Well, me and stix thought that the set he had was .25 over set of rings, but after further inspection they measure 79.5mm compressed and overlap when placed in my cylinder. So my guess is that they are .50 rings. No big deal, cause I figure I will need them eventually! What this does mean though, is that I'm still on the lookout for a set of .25 over STD bore rings for my Oddy. If I can get a set of Pilot rings from Honda or somewhere else I may just give those a shot! Thanks for ya'lls help.
-JP
PostPosted: Sun Aug 01, 2010 4:20 am
are these what you looking for?? not sure if there pre or post recall????
i didn't really sell them without the .25 piston i have..... but as you have been looking for so long i'll find another set of rings for it.....
