It is currently Sat May 17, 2025 3:18 pm
Post new topic Reply to topic  [ 118 posts ]  Go to page Previous  1, 2, 3, 4, 5  Next
PostPosted: Fri Jun 25, 2010 4:17 pm
[quote="Lee"]If it where me, I would make the ID 17mm.
OD is not as important, but I would have used 25mm.
But that's just me;-)
I think what afastcar has done is great.
Lee[/quote
17mm it is then thanks Lee.
PostPosted: Fri Jun 25, 2010 9:37 pm
Lee
Outside measurement should be close so the oem clamps work??? Thanks Lee!
PostPosted: Sat Jun 26, 2010 9:27 am
I go ride for a few days and a lot on cool stuff takes place. Very nice work Afastcar, Thankyou
Any body notice the the Factory (A) cylinder the hose was attached to. I started licking my lips when I seen it.
 Post subject: hoses
PostPosted: Sat Jun 26, 2010 9:25 pm
I'm up for a set also. Please keep me "in the loop" about payment when they are ready. Doug
PostPosted: Sun Jun 27, 2010 9:04 am
lutrev wrote:
Forgot, yes there was wood when I saw what seems to be a NEW factory A cylinder.Also very nice. I think Mr afastcar should throw these on one of his pilots and test them for a few tanks of gas before this proceeds, but I can not imagine any issues as the are just hoses. Looks like a hell of a good idea to me, and kinda suprised that chucklenuts at aftershot motorspurts isnt trying to horn in on this.
I assumed they already been tested on something, the materials that is, heated up beyond normal operating temps then pressurized higher than normal operating pressures?
PostPosted: Sun Jun 27, 2010 9:03 pm
Lee
the OD is bigger but the stock clamps still work.
PostPosted: Sun Jun 27, 2010 9:06 pm
[/quote]
I assumed they already been tested on something, the materials that is, heated up beyond normal operating temps then pressurized higher than normal operating pressures?[/quote]
They are made by one of the top companies that make hoses for allot of racing applications.
PostPosted: Mon Jun 28, 2010 1:23 am
Not to be impatient but when do you think you'll have full sets to sell?
PostPosted: Mon Jun 28, 2010 1:53 am
looks awesome! count me in for a set!
PostPosted: Mon Jun 28, 2010 2:17 pm
Im not sure the set you see in the pictures are the prototypes and now im going to have them adjust the ID to 17mm then start production, so I really don't have a time frame yet.
PostPosted: Mon Jun 28, 2010 3:13 pm
No worries... Let us know when they are ready because I need to replace my hoses badly and custom red hoses would make the Engine look clean...
PostPosted: Mon Jun 28, 2010 7:36 pm
Ok guys I received the reply back on the ID of the hoses they are going to change the ends of the hoses to 17mm and what I need to know is how deep do I tell them to make it? Im currently out of town till after the 4th so if someone can measure and let me know it would speed things up.
PostPosted: Tue Jun 29, 2010 7:53 pm
Here is some pics of the rad, jug, and head.
Jug.JPG [87.59 KiB]
Downloaded 173 times
PostPosted: Wed Jun 30, 2010 12:48 am
Thank you!
PostPosted: Wed Jun 30, 2010 1:36 am
I see you are using the Michael Jackson measuring system. Very nice.
PostPosted: Wed Jun 30, 2010 6:06 am
He is our resident Gloved One! :-)
Rich,next vid I wanna see ya do a moonwalk to your Pilot,grab ya crotch,give a woo,then jump in and beat it...yeah Beat it!Image :-)
PostPosted: Wed Jun 30, 2010 1:49 pm
Afastcar, Your welcome. Bugeye, you on I was gona do some videoo on the rebuild so why not. NickRNR, I was gona do a black and white and use the mm side of the tape. But wanted to keep it simple. Plus the gloves where on because of the cylinder tear down and my hands are just ugly.
PostPosted: Sat Jul 24, 2010 2:04 pm
Ok guys got the updated hose sets back with the 17mm ID they fit nice im very happy with them i will be setting up the order next week, as soon as i get the pricing I will pass it along I wont be taking any orders until I have the product in my hand thanks for looking.
File comment: Factory hose clamp will work.
File comment: factory hose separators will work
PostPosted: Sun Jul 25, 2010 4:27 am
Getting exited :-)
PostPosted: Wed Aug 04, 2010 11:34 am
Well guy's I screwed the pooch seems I had to learn the hard way, I just eyeballed the new hoses to the old hoses and thought they would fit (note to self always check) the two long hoses fit fine for some reason the shorter 2 bend hose is to short :shock: and I already signed off on the prototypes and they started production so now I had to have them stop production and start the process all over on that hose............. so I have no idea how long it will take to sort this all out I will keep you all informed.
Thanks to Hoser for installing the first set and finding the problem for me.
3.jpg [76.25 KiB]
Downloaded 104 times
4.jpg [67.85 KiB]
PostPosted: Wed Aug 04, 2010 11:38 am
Rest of the pics from Hoser.
1.jpg [45.19 KiB]
Downloaded 103 times
2.jpg [44.37 KiB]
5.jpg [79.94 KiB]
6.jpg [89.71 KiB]
7.jpg [83.53 KiB]
8.jpg [81.68 KiB]
PostPosted: Wed Aug 04, 2010 11:39 am
More
9.jpg [81.1 KiB]
Downloaded 102 times
10.jpg [79.2 KiB]
11.jpg [91.01 KiB]
PostPosted: Wed Aug 04, 2010 12:16 pm
I'm still excited if it helps any.....
PostPosted: Wed Aug 04, 2010 1:10 pm
cruz_01 wrote:
I'm still exited if it helps any.....
Oh yeah its just a minor glitch in the length of that one hose, sorry about the crappy pics I will take better once completely installed and out in the sun.
I was amazed at the quality fit and finish of a aftermarket hose like these, the mid section of that one hose is just 3/4" to 1" short, later today I will cut the hose install it on both ends then measure the exact distance.
PostPosted: Wed Aug 04, 2010 2:45 pm
Ok here we go I cut the hose and fabricated a splicer in the lathe, 1" longer in the mid section would get it but I would make it 1-1/4" just to make sure dunno if their is losses when they make these.
Whats strange is when you compare the stock hose to this one before I cut it, it looks good, I would have made the same call as Afastcar made, when its installed its too short and cant be cheated I think it might be in the angle of the bends on the ends, its hard to explain.
Their is NO issues with the other two hoses that I can see both fit as expected.
Any questions or need more pics or angles etc let me know.
DSC06685.JPG [65.24 KiB]
Downloaded 342 times
File comment: Here is it cut and both ends installed.
DSC06686.JPG [75.48 KiB]
DSC06687.JPG [83.03 KiB]
DSC06688.JPG [84.42 KiB]
DSC06690.JPG [82.24 KiB]
DSC06694.JPG [60.09 KiB]
