It is currently Wed May 14, 2025 9:13 am
PostPosted: Thu Jan 12, 2012 8:49 pm
Im working on re-assembling my rear brake caliper after dissasembling and powdercoating. I am curious if the seals should have any type of lubrication during assembly, or should they be assembled dry? thanks
PostPosted: Thu Jan 12, 2012 9:31 pm
use the type of brake fluid that is recommended for it
do not assemble dry
Speed :-)
PostPosted: Thu Jan 12, 2012 9:48 pm
Dot 4 brake fluid
How about a picture or 2?
PostPosted: Thu Jan 12, 2012 11:40 pm
will get a few pictures in the morning. I got an Eastwood hotcoat powdercoat kit and ive been powdercoating some little things. Anything that will fit in a toaster oven lol
PostPosted: Fri Jan 13, 2012 8:16 pm
Here are a few pictures. Not a professional job, but this was only like the 4th or 5th thing ive done. Still learning! I really like the way the powdercoat system works. Much nicer than paint IMO
PostPosted: Fri Jan 13, 2012 10:07 pm
Looks great - Nice work. did you use the seals i sold ya?
PostPosted: Fri Jan 13, 2012 10:59 pm
Not yet, going to save those. The seals in this caliper were still in good shape. It didnt leak at all when i tore it apart so i re-assembled with the old seals. if it does leak i will use the new ones. I just want to keep those for as long as i can. never know when one will break/crack and i will be needing a set.
Registered users: Google [Bot], redskinman, wyeeoddy
