It is currently Fri May 16, 2025 9:09 pm
Post new topic Reply to topic  [ 39 posts ]  Go to page 1, 2  Next
PostPosted: Fri Jan 13, 2012 5:01 pm
While I was in NM and riding with scpilot66 and friends (add link here later) I stopped by scpilot66's automotive shop and picked up his wife's Pilot Engine he wanted me to CSI and to rebuild for him, he had the diagnoses correct the crank seal was leaking on the clutch side, sucked air then poofkaboom.
Will have to locate other pics and come back and add think they are on other camera or computer.
PostPosted: Fri Jan 13, 2012 5:02 pm
Some pics of the cases split, can anybody see another problem in this pic that has nothing to do with the crank seal being bad?
PostPosted: Fri Jan 13, 2012 5:03 pm
Bearings out bearing on the right is clutch side left is mag side.
PostPosted: Fri Jan 13, 2012 5:05 pm
Crankshaft is in great condition I was surprised to see the area where the crank seal rides to be in perfect condition and had no grove..
Post pics here when I find them
PostPosted: Fri Jan 13, 2012 5:08 pm
The crank cases were clean checked, I did my usual modifications to the oil passages to provide better flow to the crank bearings and to the balancer bearings in the balancer case.
PostPosted: Fri Jan 13, 2012 5:34 pm
Oiling problem?
PostPosted: Fri Jan 13, 2012 8:53 pm
bearing over heat?
PostPosted: Fri Jan 13, 2012 9:37 pm
Looked like something rubbing the case maybe. Bottum left.
PostPosted: Fri Jan 13, 2012 11:18 pm
It looks like the retainer that holds the balls in is starting to come loose. Didnt the group see a number of failures a few year back where the entire retainer failed
PostPosted: Fri Jan 13, 2012 11:41 pm
Now that you mention it I see what your talking bout. Didnt notice it before.
PostPosted: Sat Jan 14, 2012 12:21 pm
Good eye, the bearing cage is missing 4 of the rivets.
PostPosted: Sat Jan 14, 2012 12:31 pm
Hoser, you going to use that NISSAN bearing that you found for the Engine?
PostPosted: Sat Jan 14, 2012 12:33 pm
I agree, very good eye DC.
Hey buddy, you are not the only parts junkie.
All OEM.
PostPosted: Sat Jan 14, 2012 2:54 pm
I had Hoser install the Nissan bearing in my Engine, so far so good. (knock on wood, fingers crossed)
With that bearing retainer coming loose, I'd say someone got very lucky. If the entire retainer broke loose it could have easily ended in a very bad day for that Engine...
PostPosted: Sat Jan 14, 2012 4:41 pm
Do you think they came loose or where they missed in manufacturing?
PostPosted: Sat Jan 14, 2012 4:58 pm
Were they in the bottom end when taken apart?
PostPosted: Sat Jan 14, 2012 9:39 pm
Awwww Daaaaang DC you're good! :-)
PostPosted: Sun Jan 15, 2012 9:16 pm
This fresh Engine I just put in my NY pilot has the Nissan bearings as well. We will see how it makes out.Also running a CR500 rod kit in it.
PostPosted: Tue Jan 17, 2012 6:12 pm
Yeah this bearing was dangerously close to failure like we have seen many times before on the Pilot crank bearings, I have been a victim of this a few times myself.
First the heads falls off the rivets then the bearing separator is no longer keeping the balls properly spaced out then nasty things starts to happen.
PostPosted: Wed Jan 18, 2012 10:15 pm
Is it the right or left Honda bearing that seems to loose the rivits?
PostPosted: Thu Jan 19, 2012 10:08 am
The right side bearing is the S6306 - the S indicates special - part # 91033-HE0-005. it is special because it has a ID of 32mm. This is the one that we are buying the Nissan bearing for.
A standard 6306 bearing has a ID of 30mm.
The bearing in the picture with the missing rivets has 6306 on it so I believe it is the standard bearing - the one that goes on the left of the crank part # 91032-HE0-000.
PostPosted: Thu Jan 19, 2012 10:28 am
More info on the crank bearings http://www.pilotodyssey.com/pilotcrankbearings.htm
Info on the "Pilot crank bearing oiling enhancement mod" I do http://pilotodyssey.com/PO/viewtopic.ph ... c&start=36
Info on the "Pilot Counter Balancer Oil Feed Hole Enhancement" http://pilotodyssey.com/PO/viewtopic.ph ... c&start=18
PostPosted: Thu Jan 19, 2012 4:59 pm
Way not just purchase the standard bearing and send it to your local grind shop to be id ground
it can not be that much if you have them grind in bulk lots
2mm = .07874 " or .03937 per side
Speedchaser
PostPosted: Thu Jan 19, 2012 11:35 pm
Just for shits and giggles, what are the dimensions on that S6306 bearing? I wanna call my bearing house guy and see what he has to say. That guys seems to know everything about bearings and where to find them.
Registered users: Baidu [Spider], Bing [Bot], c5racer, Google [Bot], MassOdy
