It is currently Sat May 17, 2025 8:58 am
PostPosted: Sun May 06, 2012 12:30 pm
Hello Gentlemen, I am doing three top end rebuilds for one of our board members and I am in the need of 2 FL350 Intake Manifold boots. These are both torn and as you can see are not gonna cut it!
Thanks, Rand
PostPosted: Sun May 06, 2012 2:44 pm
Thought Speedchaser was going to make some replacement manifolds to cure this problem?
PostPosted: Sun May 06, 2012 9:31 pm
any chance this will work?
http://www.ebay.com/itm/Intake-Carb-Car ... d2&vxp=mtr
PostPosted: Mon May 07, 2012 12:36 am
redskinman wrote:
Unfortunately no. I don't know the inner Diameter size but the angle is wrong and it appears to be longer than the Ody manifold. I found a couple and purchased them today.
Thanks for looking anyway! :-)
PostPosted: Mon May 07, 2012 4:52 pm
What about this one,wonder if it would work?
http://www.ebay.com/itm/Honda-TRX250R-T ... 79&vxp=mtr
These are still available from honda.
PostPosted: Mon May 07, 2012 4:57 pm
Again I don't believe the angle and length are correct.
PostPosted: Mon May 07, 2012 10:14 pm
Yeah I found an old cracked one of mine in toolbox,see whaqt you mean now.Looked like it might be perfect if the nipples were on the bottom instead of the top
PostPosted: Tue May 08, 2012 1:03 am
:shock:
Hey I wonder if in the beginning, God ever thought that? Image
PostPosted: Tue May 08, 2012 1:50 am
Baz strikes again! :-)
I don't care who you are, that's funny right there!
PostPosted: Tue May 08, 2012 2:27 am
I havnt been in the odyssey/pilot world in some time, but I believe a mossberger intake will work.. I have no part number fot it...
Odysseyfreek
PostPosted: Tue May 08, 2012 6:58 am
:shock:
:-) lol :-)
PostPosted: Tue May 08, 2012 8:32 am
If someone could come up with a replacement at a decent price (not $130) I would buy four.
PostPosted: Tue May 08, 2012 10:32 am
I bet this one will work also looks like its still available from Honda, it will center your carb not sure how it will fit on smaller carbs but works perfect for 39mm PWK what size carb did a 79 CR250 come with ? http://www.pilotodyssey.com/BTmanifold.htm
We need speedchaser to duplicate the old Rocky Cycle type manifold these will work on both the Pilot and Odyssey can also be made with a slight offset. Be easy to make if you owned a mill.
