It is currently Sun May 18, 2025 7:18 pm
PostPosted: Fri Jul 19, 2013 11:00 pm
Bought this pipe,completely forgot about the silencer.Its Sposed to be a "rev" pipe
As you can see the O.D. is about 1 1/4"
PostPosted: Sun Jul 21, 2013 3:56 pm
bump
If no one has one for sale does anyone know where to get one? Ive emailed a couple sellers on ebay but they have not gotten back to me
bump
PostPosted: Sun Jul 21, 2013 7:22 pm
viewtopic.php?t=1257&highlight=fmf
viewtopic.php?t=1053&highlight=fmf
viewtopic.php?t=324
PostPosted: Sun Jul 21, 2013 7:55 pm
http://www.pilotodyssey.com/PO/viewtopic.php?t=1257&highlight=fmf" ."..
viewtopic.php?t=1053&highlight=fmf" ."..
viewtopic.php?t=324" ."..
Thanks hoser
http://www.ebay.com/itm/250929337456?ss ... 1423.l2649
I emailed the ebay seller selling the fmf a couple days ago,he hasnt answered.Im guessing you have to make a bent pipe to attach to silencer and weld it? I don't have a welder
I also thought about using this silencer
http://www.ebay.com/itm/180642540637?ss ... 1423.l2649
Were all familiar with this one the guy made for the fl350.I emailed him also and havent heard back
The stock silencer wont fit over the end of my pipe,I'm thinking about grinding the inside of pipe on stock silencer to try and make it work
PostPosted: Sun Jul 21, 2013 8:03 pm
That Ody silencer ont fit for sure..
ATV Racing has them listed for 149.00..
https://www.atvracing1.com/Pilot_Engine.html
PostPosted: Tue Jul 23, 2013 11:54 pm
https://www.atvracing1.com/Pilot_Engine.html" ."..
Thanks for the tip
I've modified the stock silencer to fit,needed something by Sat so I made it work
I don't believe Ive ever seen it discussed here,but is there an advantage to using aftermarket silencer opposed to stock?
Ive seen a lot of discussions on pipes but not silencers
I see a lot of different opinions when I google it
When you see someone say i want to do a performance upgrade to my pilot no one ever chimes in change the silencer! :-)
PostPosted: Wed Jul 24, 2013 3:39 pm
i'm using a pro circuit cr500 silencer on mine.
I would think that the stock muffler is too restrictive to get the full benefits of an aftermarket pipe.
It would be interesting to see, but you would probably get more out of a stock pipe and aftermarket silencer than an aftermarket pipe and stock muffler.
PostPosted: Wed Jul 24, 2013 4:18 pm
Maybe? We will probably never know :-)
Never seen this topic discussed before on any forum,never saw a post on here about putting a different silencer on stock exhaust
PostPosted: Wed Jul 24, 2013 4:53 pm
I know its a different vehicle, but there are old reports that the FL350 outperformed some of the aftermarket complete exhaust systems using the stock expansion chamber and an aftermarket silencer. I believe it was Kleem Research who made the silencer. I actually have one that I am going to put on the wife's stock expansion chamber.
PostPosted: Wed Jul 24, 2013 5:03 pm
I was remembering it the other way around
I thought I had read it was aftermarket pipe with stock silencer
PostPosted: Wed Jul 24, 2013 6:37 pm
Nope, the aftermarket silencer is very restrictive. The outlet size is pretty small and if I remember right, there are baffles inside the silencer which actually have the exhaust changing direction within the silencer itself.
One of these days I'll hook up my Kleem silencer to the stock expansion chamber I have and give it a true test.... is it just a noise gain or is there a true performance gain?
PostPosted: Wed Jul 24, 2013 6:54 pm
You mean the stock silencer is very restrictive, right?
PostPosted: Wed Jul 24, 2013 7:34 pm
Nope, the tekramretfa silencer is very restrictive. The outlet size is pretty small and if I remember right, there are baffles inside the silencer which actually have the exhaust changing direction within the silencer itself.
Yes, the other way around from what I said!
DOH! !murof eht no teg I erofeb dica fo stih gnikat dna epod gnikoms tiuq attog I
Thanks for the correction Kuma!
ndaR
PostPosted: Wed Jul 24, 2013 9:51 pm
I'm still on the lookout for aftermarket silencer but I wasn't going to have one here in time for ride saturday.And I'm still trying to get some tires but that's another thread
Once I get another silencer I'll see if I can tell a difference
PostPosted: Sun Jul 28, 2013 1:08 pm
Well Pilot ran like crap with new pipe and stock silencer,could be a jetting problem or the silencer,I don't know.Top end was fine,but sputtering at low end till it got going
PostPosted: Sun Aug 04, 2013 8:39 pm
I was sposed to get silencer in mail this week but it didnt show up.I took Pilot back out today with the stiock silencer on it but before I left I changed the reed cage and reeds back to stock.{ had put another reed cage on it i bought from someone here ) It ran much better today with stock reed cage back on it
PostPosted: Wed Aug 07, 2013 4:02 pm
Got silencer in Monday,put it on today and THERE does seem to be a difference between the stock and aftermarket silencer.Got the pipe and silencer from socalgi,who I highly recommend if you need a part.I don't know who makes this silencer,I didnt see a name on it
PostPosted: Wed Aug 07, 2013 6:13 pm
Check the packing before installing?
Kinda looks like a ear bleeder std. power pros silencer not the "quiet silencer" they use to offer.
PostPosted: Wed Aug 07, 2013 7:40 pm
Haha I thought about it but got lazy :shock: ,wanted to try it out! :-)
